forumarchive,nothingtosee,
Syed2
Message 1 of 5
Inconsistent Speed & Ping
I have bought M200 Fibre Boradband deal but I am experiencing inconsistent speed and ping from the start of my contract. I have tried contacting support numerous time but the only thing they seem to suggest is to restart my hub 3.
Hopefully the community might be able to help me more than customer support.
My live BQM is attached below which shows irregular ping spikes
https://www.thinkbroadband.com/broadband/monitoring/quality/share/048293e6c3fc1e72de5607566d4c43084b41afd7
And my router network log is attached below. It has been restarted an hour ago and previously it showed Post RS errors on 2 channels in thousands
331000000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
1331000000-5.737256 qam25
2203000000-2.938256 qam9
3211000000-3.238256 qam10
4219000000-3.537256 qam11
5227000000-3.536256 qam12
6235000000-438256 qam13
7243000000-4.738256 qam14
8251000000-538256 qam15
9259000000-4.938256 qam16
10267000000-538256 qam17
11275000000-5.538256 qam18
12283000000-5.238256 qam19
13291000000-5.238256 qam20
14299000000-5.238256 qam21
15307000000-5.738256 qam22
16315000000-637256 qam23
17323000000-637256 qam24
18371000000-637256 qam26
19379000000-6.237256 qam27
20387000000-6.937256 qam28
21395000000-6.537256 qam29
22403000000-6.737256 qam30
23411000000-7.237256 qam31
24419000000-7.237256 qam32
1Locked37.330
2Locked38.940
3Locked38.950
4Locked37.6210
5Locked36.380
6Locked38.6120
7Locked38.91100
8Locked38.61060
9Locked38.61110
10Locked38.9480
11Locked38.6550
12Locked38.6880
13Locked38.6400
14Locked38.6140
15Locked38.6140
16Locked37.660
17Locked37.380
18Locked37.640
19Locked37.650
20Locked37.630
21Locked37.670
22Locked37.6110
23Locked37.360
24Locked37.670
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13940000045.5512064 qam4
25370000047512064 qam2
34620000046.3512064 qam3
46030000047512064 qam1
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Syed2
Message 2 of 5
Re: Inconsistent Speed & Ping
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID202152
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID202151
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
22/02/2021 10:22:34noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2021 08:02:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2021 12:03:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2021 10:33:37noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/02/2021 21:48:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/02/2021 11:07:4noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/02/2021 02:52:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/02/2021 01:56:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2021 21:50:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2021 21:13:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2021 18:26:8Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2021 10:26:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/02/2021 08:56:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/02/2021 03:29:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/02/2021 17:02:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/02/2021 16:23:31ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 05:02:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 04:23:31ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 00:44:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 13:56:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
sayekm
  • 298
  • 25
  • 54
Fibre optic
Message 3 of 5
The 1st issue your downstream power has dropped below the max -6. The range is -6 to +10 and you want in the middle so have room for minor fluctuation. Maybe a good idea to also post the upstream power level. You can check the area status if any local network issues..if not you will need to arrange an engineer home visit.
Your BQM indicates very congested area and if after fixing the power levels it does not improve there is no magic fix. But goverment has anounced school opening from 8th March so that may improve this a bit.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
M200 Oomph - 5GB SIM + 3 extra SIM family plan - BT whole Wi-Fi - Sky Q
Don't cry over Virgin price increase instead speak to retentions team and negotiate a better deal.
Syed2
Message 4 of 5
Hi Sayekm
Please find attach my updated router status
331000000
Locked
39400000
Locked
Provisioning State
Online
1331000000-637256 qam25
2203000000-338256 qam9
3211000000-3.538256 qam10
4219000000-3.737256 qam11
5227000000-3.736256 qam12
6235000000-4.238256 qam13
7243000000-4.938256 qam14
9259000000-538256 qam16
10267000000-5.238256 qam17
12283000000-5.437256 qam19
15307000000-5.937256 qam22
16315000000-6.237256 qam23
18371000000-6.237256 qam26
20387000000-737256 qam28
21395000000-6.737256 qam29
22403000000-6.937256 qam30
24419000000-7.437256 qam32
1Locked37.31850
2Locked38.68560
3Locked38.68480
4Locked37.38350
5Locked36.312310
6Locked38.67960
7Locked38.616430
8Locked38.617930
9Locked38.613930
10Locked38.64570
11Locked38.63270
12Locked37.611520
13Locked38.69190
14Locked38.91330
15Locked37.32320
16Locked37.61950
17Locked37.32080
18Locked37.62010
19Locked37.64152811
20Locked37.6543867
21Locked37.62650
22Locked37.32200
23Locked37.33480
24Locked37.32860
13940000045.8512064 qam4
46030000047.3512064 qam1
3ATDMA0000
4ATDMA0010
Do I need to ring Virgin and tell them to fix the power level on my line, as there is no issues in my area?
sayekm
  • 298
  • 25
  • 54
Fibre optic
Message 5 of 5
You need to call customer service and get that downstream power sorted...its below the acceptable range. Don't accept any crap on the phone about its normal and insist on an engineer apointment ASAP.
