Widz
Inconsistent Speed & Packet Loss
Hi All, for the past 2 weeks or so the speed of my Gig1 Package has been all over the place on the download side; and for the past few days the upload speed has also now dropped severely. (down to 35 and under from being solid at 45+ every test)
Also at the same time packet loss has gone from nothing for months to suddenly a constant 5 - 20% and this of course plays havoc on trying to play any game.
I've started a BGM monitor (live output below)
My Broadband Ping - VM packetloss
 And a snapshot of my recent speedtest.net history opera_2021-01-07_18-50-19
This seems to be a wider issue creeping up looking across social media and happening to friends across the country so I'm hoping it's down to a change or infrastructure upgrades going on across the VM network...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Inconsistent Speed & Packet Loss
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
