on 01-10-2021 11:00
Ive been getting inconsistant speeds for quite a while now, i have 200mb package and my speeds range from 16.9 to 217 most of the time it is well below the 200. Ive bought a mesh Tplink Deco M9 to see if it helped and it doesnt it just gives me better signal. My details are below if anybody can help:
1 | 298750000 | 5.3 | 38 | 256 qam | 21 |
2 | 138750000 | 3.5 | 37 | 256 qam | 1 |
3 | 146750000 | 3 | 37 | 256 qam | 2 |
4 | 154750000 | 3.2 | 37 | 256 qam | 3 |
5 | 162750000 | 3.2 | 37 | 256 qam | 4 |
6 | 170750000 | 3.5 | 38 | 256 qam | 5 |
7 | 178750000 | 4 | 38 | 256 qam | 6 |
8 | 186750000 | 4.4 | 38 | 256 qam | 7 |
9 | 194750000 | 4.5 | 38 | 256 qam | 8 |
10 | 202750000 | 4.4 | 38 | 256 qam | 9 |
11 | 210750000 | 4 | 38 | 256 qam | 10 |
12 | 218750000 | 3.5 | 38 | 256 qam | 11 |
13 | 226750000 | 3.2 | 38 | 256 qam | 12 |
14 | 234750000 | 3 | 38 | 256 qam | 13 |
15 | 242750000 | 3 | 38 | 256 qam | 14 |
16 | 250750000 | 3.2 | 38 | 256 qam | 15 |
17 | 258750000 | 3 | 38 | 256 qam | 16 |
18 | 266750000 | 3.2 | 38 | 256 qam | 17 |
19 | 274750000 | 3.4 | 38 | 256 qam | 18 |
20 | 282750000 | 3.9 | 38 | 256 qam | 19 |
21 | 290750000 | 4.5 | 40 | 256 qam | 20 |
22 | 306750000 | 5.5 | 38 | 256 qam | 22 |
23 | 314750000 | 5.6 | 38 | 256 qam | 23 |
24 | 322750000 | 5.6 | 38 | 256 qam | 24 |
1 | Locked | 38.9 | 5 | 0 |
2 | Locked | 37.6 | 8 | 0 |
3 | Locked | 37.6 | 10 | 0 |
4 | Locked | 37.6 | 5 | 0 |
5 | Locked | 37.6 | 0 | 0 |
6 | Locked | 38.6 | 0 | 0 |
7 | Locked | 38.6 | 6 | 0 |
8 | Locked | 38.9 | 4 | 0 |
9 | Locked | 38.9 | 4 | 0 |
10 | Locked | 38.9 | 5 | 0 |
11 | Locked | 38.6 | 5 | 0 |
12 | Locked | 38.6 | 5 | 0 |
13 | Locked | 38.9 | 5 | 0 |
14 | Locked | 38.9 | 6 | 0 |
15 | Locked | 38.6 | 7 | 0 |
16 | Locked | 38.9 | 8 | 0 |
17 | Locked | 38.6 | 13 | 0 |
18 | Locked | 38.9 | 12 | 0 |
19 | Locked | 38.9 | 4 | 0 |
20 | Locked | 38.9 | 1 | 0 |
21 | Locked | 40.3 | 5 | 0 |
22 | Locked | 38.9 | 5 | 0 |
23 | Locked | 38.9 | 3 | 0 |
24 | Locked | 38.9 | 6 | 0 |
1 | 39399969 | 45.5 | 5120 | 64 qam | 2 |
2 | 53700000 | 47 | 5120 | 64 qam | 5 |
3 | 25800000 | 45 | 5120 | 32 qam | 4 |
4 | 32599988 | 45.5 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
I will post network log speratly as message has exceeded the max characters
on 01-10-2021 11:00
01/10/2021 09:37:50 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/10/2021 09:05:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/10/2021 09:05:8 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/10/2021 09:04:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/10/2021 04:09:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/10/2021 04:08:15 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/09/2021 21:24:58 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/09/2021 15:35:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/09/2021 13:32:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/09/2021 13:32:19 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/09/2021 02:45:1 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/09/2021 02:45:0 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/09/2021 01:35:47 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/09/2021 01:35:47 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/09/2021 12:25:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/09/2021 02:40:52 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/09/2021 02:40:52 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/09/2021 23:52:17 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/09/2021 22:21:56 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/09/2021 14:40:52 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 01-10-2021 15:57
on 02-10-2021 15:18
Thanks for the reply John,
Ive tried everything you sugested all connections are tight and still my download speed is 46.25Mb.
1 | 46200000 | 41.3 | 5120 | 64 qam | 1 |
2 | 25800000 | 39.8 | 5120 | 64 qam | 4 |
3 | 32599983 | 39.8 | 5120 | 64 qam | 3 |
4 | 39400039 | 41.3 | 5120 | 64 qam | 2 |
All upload channels are at 64 qam now.
on 02-10-2021 15:42
Profile of downstream power levels look erratic - a bit of a bathtub profile against frequency, when they should be moderately tightly clustered and falling slightly as frequency rises. Can't say if that's material, but network log confirms a stinky connection.
I think a technician is needed, and unless they can find a noise issue to explain the symptoms, it may need the slope of power levels adjusting on any street cabinet amplifier. Be aware that there's different grades of technician, some have RF running through their veins instead of blood, and that's the type you want. Some of the others may not have a scooby what the numbers mean, even from their own equipment.
on 02-10-2021 15:52
Thanks Andrew,
Ive just tried removing the splitter to see if that does anything and the speed has increased to 115.8Mbs.
Dont know is this means bad splitter or bad wires?
but still not the 200 expected.
Rob
on 04-10-2021 16:17
Hi robwhilton,
Thanks for posting and sorry to hear you've had some issues with the speed.
I've been able to locate your account using your forum information, I've been through a few checks and it does look like an engineer is required.
I'll need a few more details from you so I can arrange this so I've sent you a private message (purple envelope, top right hand corner)
Alex_Rm
