TaylorBrown
Just joined
IG Speed Issue?
I recently upgraded to the 1G Superhub 4, since then I've had nothing but issues. Like most people I'm working from home and the connection on my work PC is so bad it's almost impossible to do zoom calls. I get getting a messages saying my internet connection in unstable.
On my own PC which is connected via ethernet I get this on Sam Knows 1024 to the hub and 192 to my PC. My son's PS4 gets 6mps when wired and 9mps via wi-fi. On an Iphone 11 I get 49mps via wi-fi. I have an Alexa in each room and they constantly lose connection. I spent 4 hours yesterday on the phone to Virgin (3.30 in various queues) and they couldn't see anything wrong but I've said I want an engineer out.
I'm not the slightest bit technical and had no idea about power levels although I see a lot of posts about those on here. I've copied this from my router to see if anyone who is far more technically advance than me can see if they can see any issues.
Thanks for taking a look
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: IG Speed Issue?
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: IG Speed Issue?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: IG Speed Issue?
Can you please
Hub 4 When the page appears LOG IN then Advanced settings > Tools > Network Status.
