I have looked at a few posts related to speed issues and gone about setting up a BQM and run some ping tests. I think, from comparing my figures to views online and in this community, that my latency is high.
I run the Virgin Hub3.0 as a modem and use a Tplink AX50 for other network aspects, which I upgraded to from my old router. I also have 4 PowerLans running to try and remove WiFi for a couple of work laptops, a "Zwift" PC and the TV.
For example:
Pinging www.google.com [172.217.169.68] with 32 bytes of data:
Reply from 172.217.169.68: bytes=32 time=686ms TTL=115
Reply from 172.217.169.68: bytes=32 time=927ms TTL=115
Reply from 172.217.169.68: bytes=32 time=700ms TTL=115
Reply from 172.217.169.68: bytes=32 time=519ms TTL=115
Ping statistics for 172.217.169.68:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 519ms, Maximum = 927ms, Average = 708ms
I ran this on one other machine too and got similar figures. I will go about testing on wifi / direct connection to router / PowerLan connection, etc... but need to wait for the end of our 'working' day here at home.
Can anyone help me work out how to rule out issues.
