yeshikebt78
Just joined
Message 1 of 10
I test my WiFi speed
My router is downstairs and my room is upstairs and when I test my WiFi on my PHONE download and upload I get good results I try on each website and they are similar stats but whenever I game on my PS4 wireless I get bad ping and lag spikes?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: I test my WiFi speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 10
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Anonymous
Not applicable
Message 4 of 10
you should use a wired connection. Look at some power line adapters
Anonymous
Not applicable
Message 5 of 10
how would it be signal related if its getting good speeds on all other devices?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 10
There is nothing wrong with confirming that everything is good or noting things that may not be evident in normal use.
Anonymous
Not applicable
Message 7 of 10
waste of time though
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 10
It isn't a waste of your time !!
Anonymous
Not applicable
Message 9 of 10
no its a waste of the ops time. But i guess it gets your post count up so I'll leave you to it
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 10
OK then. I'm out of this one. Please take over.
You should have all the information that YOU need.
PS
I don't give a stuff about post counts, Helpful Answer counts or Kudos, they don't mean anything.
