Hub5 - Significant loss of speed to hub from VM
Schmill
Dialled in
So I have been having a "bad internet connection" for a few weeks, finally got fed up of running the VM Connect app and rebooting the router so started to poke around a bit more.
I have used both the VM "check my kit" test, and also the www.samknows.com/realspeed test and can see quite clearly that the issue is "VM to Hub", not my 'in house network'. I should be on 1Gb broadband, but am often seeing speeds of ~100Mbps to the Router.
I've been through all the hoops of "turn it off and on again" and "reset to factory defaults", and they all have the same effect, it fixes it! Back to >1000Gbps... for a few hours at best, and then back down again.
Had an engineer visit yesterday, did a noise check on the cable to the house, all seemed well, did a check inside the house, all seemed well, couldn't determine a cause, suggested it might be bad firmware or a faulty hub and swapped the hub out. Of course in the 30 minutes that he had been allocated for the job that was about time-up and of course everything was back to >1000Gbps again (as it would have been with a reboot of the old hub).... and then a few hours later it was back down again.
Its easily repeatable, but the engineer himself said he doesn't know what to do next as everything "looks ok"...
I've been gathering data from the router, but not really sure what to do with it, hence posting here.
I have a lot more data if needed, but as an illustration see the comments following (due to VM limit on characters per post).
When the engineer was here he said if it was a "cabinet issue" then it was not something he could resolve, but then also after doing his testing on the line he didn't seem to think it was a cabinet issue...
Where do we go from here?
My Broadband Ping - My VM Connection
14 REPLIES 14
Schmill
Dialled in
At 19:57 last night (running on the new hub, shortly after a restart)
At 23:00:
At 23:25 (after rebooting the hub):
and then checking again this morning at 08:00:
Schmill
Dialled in
RxMER for each downstream channel in use:
and PreRS Errors for the same:
Schmill
Dialled in
There is very little difference in the powers between when it IS working and when it is NOT working:
20231012-2325 (After router reboot) - 1146Mbps downstream:
1331000000-2.740QAM 25625
21390000000.540QAM 2561
31470000000.340QAM 2562
4155000000040QAM 2563
51630000000.140QAM 2564
61710000000.240QAM 2565
71790000000.441QAM 2566
81870000000.940QAM 2567
91950000000.441QAM 2568
102030000000.441QAM 2569
112110000000.641QAM 25610
12219000000-1.240QAM 25611
13227000000-1.540QAM 25612
14235000000-1.740QAM 25613
15243000000-2.240QAM 25614
16251000000-2.240QAM 25615
17259000000-241QAM 25616
18267000000-1.741QAM 25617
19275000000-1.641QAM 25618
20283000000-1.641QAM 25619
21291000000-1.741QAM 25620
22299000000-1.741QAM 25621
23307000000-1.941QAM 25622
24315000000-2.440QAM 25623
25323000000-2.540QAM 25624
26339000000-2.940QAM 25626
27347000000-2.940QAM 25627
28355000000-2.840QAM 25628
29363000000-2.540QAM 25629
30371000000-2.840QAM 25630
31379000000-2.840QAM 25631
1Locked4000
2Locked4000
3Locked4000
4Locked4000
5Locked4000
6Locked4000
7Locked4100
8Locked4000
9Locked4100
10Locked4100
11Locked4100
12Locked4000
13Locked4000
14Locked4000
15Locked4000
16Locked4000
17Locked4100
18Locked4100
19Locked4100
20Locked4100
21Locked4100
22Locked4100
23Locked4100
24Locked4000
25Locked4000
26Locked4000
27Locked4000
28Locked4000
29Locked4000
30Locked4000
31Locked4000
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
04960000045.85120QAM 641
143100000455120QAM 642
23660000044.55120QAM 643
33010000043.85120QAM 644
42360000043.85120QAM 645
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
0ATDMA0030
3ATDMA0000
4ATDMA0000
20231013-0800 (80Mbps downstream)
1331000000-2.840QAM 25625
21390000000.640QAM 2561
51630000000.240QAM 2564
61710000000.340QAM 2565
71790000000.840QAM 2566
81870000000.741QAM 2567
14235000000-1.840QAM 25613
16251000000-2.340QAM 25615
18267000000-1.841QAM 25617
19275000000-1.741QAM 25618
20283000000-1.741QAM 25619
21291000000-1.841QAM 25620
22299000000-1.841QAM 25621
24315000000-2.540QAM 25623
25323000000-2.640QAM 25624
26339000000-340QAM 25626
27347000000-340QAM 25627
28355000000-2.940QAM 25628
29363000000-2.641QAM 25629
30371000000-2.939QAM 25630
31379000000-2.940QAM 25631
1Locked40690
2Locked4000
3Locked4000
4Locked4010
5Locked4000
6Locked4000
7Locked4000
8Locked4100
9Locked4160
10Locked4100
11Locked4100
12Locked4000
13Locked4030
14Locked4030
15Locked4000
16Locked4000
17Locked4100
18Locked4100
19Locked4110
20Locked4110
21Locked41510
22Locked4120
23Locked4170
24Locked4030
25Locked40560
26Locked40440
27Locked40600
28Locked40620
29Locked4190
30Locked39150
31Locked40210
04960000045.35120QAM 641
14310000044.55120QAM 642
236600000445120QAM 643
42360000043.35120QAM 645
0ATDMA0030
3ATDMA0000
4ATDMA0000
Schmill
Dialled in
The Network Log on the router contains a number of WARNING messages, but I assume that needs sorting on VMs side if it is an issue (the time stamps are also generally wrong by a few hours...) - MAC addresses removed "in case" - if anyone from VM needs them let me know...
13-10-2023 01:24:39noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
13-10-2023 01:24:24warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
13-10-2023 01:24:24noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
13-10-2023 01:24:21noticeREGISTRATION COMPLETE - Waiting for Operational status
13-10-2023 01:24:15warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
13-10-2023 01:24:15warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
13-10-2023 01:24:15warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
13-10-2023 01:24:15warningDynamic Range Window violation
13-10-2023 01:24:10noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
13-10-2023 01:23:58warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
13-10-2023 01:23:55noticeHonoring MDD; IP provisioning mode = IPv4
13-10-2023 01:23:35criticalNo Ranging Response received - T3 time-out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
13-10-2023 01:23:32criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-10-2023 01:23:20criticalCable Modem reboot from UI
12-10-2023 20:59:17criticalNo Ranging Response received - T3 time-out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
12-10-2023 20:59:12criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
12-10-2023 20:59:00criticalCable Modem Reboot via RG reboot command
12-10-2023 20:56:17criticalNo Ranging Response received - T3 time-out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
12-10-2023 20:56:11criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-10-2023 20:55:59criticalCable Modem reset to Factory Default via reset button
Its hard to know whats going with speed to hub and to device sometimes, check your wired device is linked at 1Gb and not 100Mb
The SamKnows utility and the VM Connect app actually perform a "speed from VM to router" test as well as the "router to device" test. It is the "speed from VM to router" (shown on the left side of my screenshots) that is the issue here, so my ethernet cable (or wireless) won't be making any difference to that.
Legend
Check for a local service fault affecting your street via : 0800 561 0061 - it is an automated service.
Thanks, but nope, nothing
Yes speed to hub dips low but when it don't your speed stays under 100Mb so check your link speed
See Network Adapter Speed in Windows 10 | Tutorials (tenforums.com)
CMD
wmic nic where netEnabled=true get name, speed, MACAddress
should show 1000000000
