paulreset
  • 5
Message 1 of 13
Hub4 on 1gig line - wifi less than 400
I upgraded to the Gig 1 line last week and replaced my Hub 3 with a Hub 4. Since then the wifi speeds have actually been lower than they were when I was on the 500 package.
I’ve run a SamKnows test and the right speed is coming into the router, it’s just the wifi is a lot slower, then than 400 most of the time (I was getting almost 500 on the 500 plan most of the time)
Any help would be much appreciated!
Thanks, Paul 
  • 5.63K
  • 462
  • 1.42K
Message 2 of 13
Re: Hub4 on 1gig line - wifi less than 400
VM do not guarantee wifi speeds.  You need to test with a Cat 6a cable wired directly to the Hub with a gigabit capable device.
You could also split the SSID and manually set your wifi devices to the 5Ghz band, as it is the fastest.
• Access your Hub by navigating to 192.168.0.1
• Login with the default login info (on base of Hub) unless you've already updated it.
• Go to Advanced Settings > Wireless > Security
• Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID), suggest append _2 to the end.
• Repeat for the Wireless Frequency 5GHz, suggest append _5 to the end and click on Apply changes
• Try to avoid spaces and periods in the SSID names as they can cause issues with certain devices.
jhuk
  • 3.2K
  • 55
  • 309
Problem sorter
Message 3 of 13
It would seem (I cannot remember TBH) the HUB3 has better WIFI than the HUB4 but you would be looking at approx. 600Mb/s Max in ideal conditions in the same room or with a WIFI POD in other rooms so 500Mb/s was good depending on surroundings/devices on your old HUB.
Zach_R
  • 3.11K
  • 99
  • 219
Message 4 of 13
Hi @paulreset,
I'm very sorry to hear you're having some problems with your wireless/Wi-Fi connection since changing to a Hub 4. Are all devices being impacted by this, or only certain ones?
Can you also test a wired connection (if you haven't already) to see if you're having any issues with that too?
Zach - Forum Team
paulreset
  • 5
Message 5 of 13
Hi Zach,
Thanks for getting back to me - all devices are being impacted - I've just tested using a wired connection and I'm only getting about 200 (varies between 180 and 220) at most.
Any ideas - could there be an issue with the router? Are there any other tests I can run to help get to the route of the problem?
Thanks, Paul
Steven_L
  • 7.94K
  • 488
  • 805
Message 6 of 13
Thanks for coming back to us @paulreset and I'm sorry to hear of your issues.
I have looked into your account and can see that there is a power level issue on your account that could be causing these issues and would need a technician visit to resolve this. I can arrange the appointment from here but would need to confirm a few details via a private message, that I will drop over in a moment.
Please look out for the private message and we can get started.
Regards,
Steven_L
paulreset
  • 5
Message 7 of 13
Thanks Steven, I don’t seem to have a private message yet but will keep an eye out.
paulreset
  • 5
Message 8 of 13
Hi Steven - still no sign of a private message?
Stobbsy74
  • 143
  • 41
Superfast
Message 9 of 13
Make sure you are signed in, and click on the purple envelope at the top of the screen.
paulreset
  • 5
Message 10 of 13
Thanks, yeah I’m logged in. No message.
