TrojanC
  • 287
  • 31
Superfast
Hub4 modem mode
package: Gig1
My Hub4 is In Modem Mode
connected to TP-Link R600 Router
(tp-link 225 EAP access point plugged into router)
wifi coverage is brilliant and not an issue -
Router connected to Hub4 using cat7 Ethernet cable to port1 on the Hub4
Speedtest only shows 250Mbps download
Upload speed 42Mbps
VM happy camper 🙂 Hub4 NextGen360 Gig1 [modem mode] TP-Link Router + 3x EAP’s
  • 17.07K
  • 731
  • 1.71K
Re: Hub4 modem mode
That is slowing you down.
I take it your testing by wire and not wireless?
TrojanC
  • 287
  • 31
Superfast
Re: Hub4 modem mode
Yes testing by Ethernet
R600 is a router (non-wireless)
it has a much better chipset than the Hub4 and is very stable.
how can it possibly slow the Gig1 from Hub4 down?
