Need some help, frustration mounting. 🙂
I've upgraded to the Hub4 1Gb a few days ago.
samknows.com/realspeed/ tests consistently give me over 1Gb to the router (Speed to Virgin Media Hub 4). From the Hub4 to any of my PCs and laptops connected directly to the back of any of the 1Gb ports on the Hub4 I'm getting between 80Mb and, if lucky, 200Mb Download speeds. Upload is stable and at the expected speed of 50+Mb.
I've tried everything I can think of. All my cables are rated at CAT 5e, swapped cables, tried different computers, all the machines have 1Gb cards, still the same, all tested directly to the back of the router.
Speedtest Ookla also gives me max 200Mb, this is less than what I used to get with my Hub3.
Any help is appreciated, I am at my wits' end!
Thanks.
