Phatz
  • 21
Message 11 of 37
Re: Hub4 Modem Mode Slow ASUS GTAC5300
Hi just an update and to close the thread.
Simply put. Unplugged the CAT7 patch cable from the wall outlet to the ASUS router. Swapped the cable. Wan status changed to 1GB port. Swapped the cable back to the original patch cable and the router stayed at 1GB on the port? Scratch head hit head against wall.
Either way back up to the 600 hundreds now!
thanks for your help
DJ_Shadow1966
  • 6.87K
  • 1.31K
  • 1.9K
Message 12 of 37
Hello
As strange as it sounds, could have been a dirty connector which is not making proper contact in the Ethernet Socket and the process of removing and reinserting the cable has cleaned / made the connection secure.
Regards Mike
Phatz
  • 21
Message 13 of 37
Have had to come back to this. I realise now that the HUB4 seems to be having issues with negotiating to the ASUs router wan port I have. The wan port status drops to 100mb and then when I take the wan cable out and plug it back in it reverts to 1GB on the port status. After a while the port status drops back down to 100mb. After doing a rinse and repeat I.e take lead out plug back in port reflected back to 1GB?
This makes me believe there is a problem with the HUB4 not maintaining its negotiation on the port of 1GB?
At present I have put in a simple switch between the HUB4 in router mode which is then connected to the router wan port. At present 1GB is holding.
I am also only getting approx 500mbps directly connected to my router which concerns me when I am supposed to be getting a gig...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 14 of 37
What speed do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Phatz
  • 21
Message 15 of 37
Yep reset to factory default router mode.
Plugged direct with cable from laptop to HUB4. HUB4 shows the laptop on 1000m connection. Laptop shows 1000/1000 Link speed receive transmit.
went to Sam knows and received
19.3,latency, 373.4 mbps download and 54.4mbps upload
Antivirus and firewall are turned off on laptop.
Did a speed test on Speedtest ookla and got 410mbps download, ping 9ms and upload of 52.22 mbps. So at present it seems am not getting the perf I was expecting?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 16 of 37
Can you go into the Hub Settings and copy and paste the contents of the Configuration Tab onto here please.
Phatz
  • 21
Message 17 of 37
I think this is is it.
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
873254k;fg87dsfd;kfoA,.iy
SFID
898
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
897
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 18 of 37
Phatz
  • 21
Message 19 of 37
Hi, Think this is it. The HUB is in Router mode and only the device connected.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/91ed1e58bb6cc31d2aae5398afb6c66e14...
Phatz
  • 21
Message 20 of 37
Hi Mike is it ok to change the hub to modem mode and connect it back up to my ASUs router? I assume this is monitoring from the Hub internet side? Thanks
