Hub3 struggling to connect to Internet
Dusty0dusty
After 8ish every night my bandwidth keeps dropping so low that I cant stream from my virgin box. I am getting errors saying bandwidth is to low or you are not connected to the Internet.
I have tried everything. Resetting the rooter, plugging things in directly. Checking cables. Running diagnostics, rebooting hub. Nothing has worked.
I have been a customer for 4 days and i am considering going with a different supplier. My hub 3 is showing an orange status light and after researching the Internet apparently this might mean the hub is faulty, as its supposed to be white.
1 ACCEPTED SOLUTION
Accepted Solutions
I'm so sorry to hear this @Dusty0dusty
Can you post your Hub status and logs? How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum.
Thank you.
6 REPLIES 6
Matthew_ML
Hey Dusty0dusty, thank you for reaching out and a warm welcome to the community, I am sorry to hear you are having some issues with your connection.
I understand this is very frustrating , however I have taken a look from our side and I can see you have spoke to the team about this.
Did they manage to get this resolved for you? Thanks
Matt - Forum Team
New around here?
Hi Matt,
The engineer did come out today and said it was feedback from a second box on the property which he delt with. Unfortunately the problem is still ongoing and the internet is still dropping out.
Sam
Thanks for getting back to us however apologies for the problems still appearing.
From checking our system I can't currently see any readings that would attribute to this, can I ask are the same lights still showing on this router?
Let us know,
Kain
Yes tge same orange light is showing on the router. The wifi sign came on during set up. Everything seemed to be working well, but unfortunately the signal keeps dropping out.
Sam
Thank you.
Sorry I am unsure on how to reply and attach the things you have asked for, the quick reply seems to be my only option.
