bigwing
Hub Swap needed from SH1?
M100 package, only seeing 40-50.
Otherwise good enough connection, has been unproblematic for years. My hub is ancient, I believe SH1 (VMDG480).
Not normally as issue, but with everyone at home I would be keen to figure out if I've just been forgotten to be upgraded somewhere along the years!
Anyone seen similar, any thoughts appreciated
Thanks.
DJ_Shadow1966
  • 6.66K
  • 1.28K
  • 1.81K
Re: Hub Swap needed from SH1?
Hello
Yes it is the original superhub and you can a new hub 3.0 at https://www.virginmedia.com/shop/hub-swap.html?buspart=uk_app_connect2_hubswap, although the hub is more than capable of doing 100mbps.
Are you doing a speedtest with a direct Ethernet connection to the hub ?
Regards Mike
bigwing
Thanks for the prompt response Mike.
I've tried a that link a few times over the last couple weeks, and I just the "oops page". Assuming there's nothing that can be done online with that, so I'll put it on the list for post covid phonecall to VM call centre in the summer.
Good news thought is it was 100% my fault, wired and 5GHz WiFi are seeing full bandwidth 100-110M. My laptop strangely started to prefer the 2.4Ghz WiFi - presumably running 802.11g which totally explains it as that's the Max speed for that standard. Just thought I'd update incase anyone else see similar
Thanks for your help, stay well.
