K14
Settling in
Hub 5
We installed new new hub5 yesterday & are now experiencing poor connectivity & range. I qe tried to reinstall our old hub but this no longer works.
Attempted to contact domeone this morning but the phone options are hopeless & take you round in circles.
Links sent don't work.
Such poor service from Virgin & we didn't ask for a new hub. It seems every upgrade is worse than the one before.
  • 6.82K
  • 593
  • 1.79K
Re: Hub 5
Post the power levels, Pre and PostRS errors and network log from the Hub. Also setup a BQM to monitor your circuit www.thinkbroadband.com/ping Once done we can comment.
Also try splitting the SSID and manually choosing the wifi bands.
• Access your Hub by navigating to 192.168.0.1
• Login with the default login info (on base of Hub) unless you've already updated it.
• Go to Advanced Settings > Wireless > Security
• Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID), suggest append _2 to the end.
• Repeat for the Wireless Frequency 5GHz, suggest append _5 to the end and click on Apply changes
• Try to avoid spaces and periods in the SSID names as they can cause issues with certain devices.
Set the Hub 5 for legacy wifi if it is not connecting to older wifi kit.
Go to Advanced Settings > Wireless > Wireless signal
In the Wireless frequency 2.4GHz select Wireless mode > 802.11b/g/n/ax mixed
Select Apply changes
If this all fails, ask for the Hub 5 to be replaced with an older Hub, as it's not working for your circumstances.
  • 35.11K
  • 3.42K
  • 6.68K
Re: Hub 5
If you just want the old Hub back on (the best solution!) - it needs re-activating on your account.
Call the equipment activation number on - 0800 953 9500 (option 3) – you will need the serial number/MAC address off the barcode sticker of the old Hub and also your account number,
