Some tests.
Methodology. mtr/traces are done from one host on my network which has no VPN on it at all. Speedtests are done from another host with the vpn up or down as noted. HOSTAT-AS29550 is the same IP/server in all cases. Test done in the 1/2 hour up to the time stamp on this post so not peak time?
I would expect, regardless, that the traces will be consistent as in both cases the connection is being fully loaded by a speed test so loss (if any) should happen on both if the hub can cope. They are however not.
VPN up to HOSTAT-AS29550 and speed test running.
Speed test results:
Speedtest by Ookla
Server: Kubbur - London (id = 47380)
ISP: Simply Transit Ltd
Latency: 15.11 ms (0.78 ms jitter)
Download: 88.72 Mbps (data used: 98.8 MB )
Upload: 25.77 Mbps (data used: 41.6 MB )
Packet Loss: 0.0%
Trace to same host but NOT via VPN at the same time
# mtr -c 30 --report HOSTAT-AS29550
Start: 2022-04-26T22:07:44+0100
HOST: xxx Loss% Snt Last Avg Best Wrst StDev
1.|-- 192.168.5.1 0.0% 30 0.3 0.2 0.2 0.3 0.0
2.|-- ??? 100.0 30 0.0 0.0 0.0 0.0 0.0
3.|-- lutn-core-2a-xe-233-0.net 6.7% 30 9.4 21.3 8.2 40.2 10.3
4.|-- ??? 100.0 30 0.0 0.0 0.0 0.0 0.0
5.|-- eislou2-ic-4-ae0-0.networ 10.0% 30 46.6 25.4 11.2 63.7 16.1
6.|-- the-linx.as29550.net 3.3% 30 20.2 23.6 11.5 66.9 13.4
7.|-- ae1-cr0.rdg.as29550.net 6.7% 30 25.9 24.8 12.3 60.0 12.0
8.|-- 92-48-64-98.static.as2955 6.7% 30 15.3 29.0 11.5 79.2 18.6
9.|-- HOSTAT-AS29550 0.0% 30 10.9 18.2 10.9 39.3 7.6
Now without the VPN up:
Speedtest by Ookla
Server: YouFibre - Slough (id = 49269)
ISP: Virgin Media
Latency: 10.29 ms (4.76 ms jitter)
Download: 382.68 Mbps (data used: 412.6 MB )
Upload: 36.98 Mbps (data used: 18.0 MB )
Packet Loss: Not available.
Start: 2022-04-26T22:14:21+0100
1.|-- 192.168.5.1 0.0% 30 0.2 0.2 0.2 0.3 0.0
3.|-- lutn-core-2a-xe-233-0.net 0.0% 30 9.6 74.7 8.6 245.2 88.8
5.|-- eislou2-ic-4-ae0-0.networ 0.0% 30 10.0 76.2 10.0 264.1 91.0
6.|-- the-linx.as29550.net 0.0% 30 10.8 74.0 10.0 250.3 88.5
7.|-- ae1-cr0.rdg.as29550.net 0.0% 30 14.7 71.1 12.6 264.1 84.3
8.|-- 92-48-64-98.static.as2955 0.0% 30 12.5 73.7 12.5 254.9 86.6
9.|-- HOSTAT-AS29550 0.0% 30 12.9 68.6 11.4 241.3 84.8
An example with a UDP VPN to DigitalOcean and a speedtest capping out at 50odd Mbps:
# mtr -c 30 --report digitalocean
Start: 2022-04-26T22:24:08+0100
1.|-- 192.168.5.1 0.0% 30 0.2 0.2 0.2 0.4 0.1
3.|-- lutn-core-2a-xe-233-0.net 3.3% 30 14.8 27.6 8.2 46.9 13.3
5.|-- m686-mp2.cvx1-b.lis.dial. 0.0% 30 14.3 30.2 10.2 93.5 21.2
6.|-- 213.46.174.118 0.0% 30 10.7 28.9 10.7 91.0 17.6
7.|-- ldn-bb1-link.ip.twelve99. 6.7% 30 13.6 28.4 11.8 60.6 15.0
8.|-- slou-b1-link.ip.twelve99. 6.7% 30 13.7 34.7 11.9 70.6 16.5
9.|-- digitalocean-ic306494-slo 3.3% 30 13.6 36.0 13.6 76.4 16.2
10.|-- ??? 100.0 30 0.0 0.0 0.0 0.0 0.0
11.|-- ??? 100.0 30 0.0 0.0 0.0 0.0 0.0
12.|-- ??? 100.0 30 0.0 0.0 0.0 0.0 0.0
13.|-- digitalocean 0.0% 30 13.2 21.6 11.1 47.0 13.5
There's clearly something here struggling with a large volume of UDP packets. There are occasions where even with the VPN up it manages to max out the line, although this is more often towards Digital Ocean not AS29550, but even then that is not consistent. I'm not aware of anything else on my network that's using bandwidth in this amount while I'm testing.
Thoughts?
Simon
