newbie01
Message 1 of 8
Hub 5 setup with Ubiquiti UniFi 6 Long-Range Access Points
Hi All,
I cannot seem to get to the bottom of this issue setting up the Hub 5 (Gig1 package) to work with my APs (UniFi 6 LR) and would appreciate any advice on what I may be missing. I am getting 700mpbs via Hub 5 (WiFi) but only 250mpbs via the APs and via an ethernet cable to any of the ports on the Hub 5.
My setup:
Hub 5 (Gig1 package) ->
TP-LINK TL-SG1024D Network Switch ->
TP-Link TL-SG1008MP 8-Port Unmanaged Rackmount Gigabit PoE+ Switch (126W) ->
I need to setup this way to allow for power to the APs and to connect the amount of devices wired in the house (IP cameras, TVs, Smart lights, etc)
The Hub 5 was tested on Modem mode however there were MAC address issues this way and so I had to revert to the Router mode on the Hub 5.
  • 20.45K
  • 828
  • 2.2K
Message 2 of 8
Re: Hub 5 setup with Ubiquiti UniFi 6 Long-Range Access Points
Just limited bandwidth on VM network see what you get with a Steam download
  • 1.8K
  • 110
  • 409
Super solver
Message 3 of 8
As your Hub is in Router mode have you tries this Hub test :
newbie01
Message 4 of 8
Thank you for your reply, I have checked d/l speeds and max out 300mpbs on a Wi Fi connection to an AP.
newbie01
Message 5 of 8
Samknows gives the following results;
1142mbps to the Router
186mbps to device
  • 6.79K
  • 591
  • 1.78K
Message 6 of 8
Try an AP directly in the Hub 5 using an injector.
  • 13.85K
  • 1.07K
  • 2.81K
Message 7 of 8
Are you running the UniFi Network Application anywhere? It can be installed on a Mac, Windows machine and even a Raspberry Pi. Also there is an app for iPhones & Android phones. It is very useful for looking at problems. I have it installed on my UDM Pro.
newbie01
Message 8 of 8
The fix for this issue is to sync all APs in one account - leave the channel setting to auto and to change the bandwidth to 80hz (using UniFi’s app).
Now I get 850mbps via all APs
