Hub 5 Speed Issue
dadya06
hey everybody i recently purchased the hub 5 for virgin media with a speed off approximately 1130 mbs but with a guarantee of it being 563 mbs. on my S22 the speed is 408mbs download with 48.3mbs. the issue i have is that on my pc the speed is 24.9mbs. i have tried looking online, tried restarting my router, changed settings on my pc and it is still at a maximum of 24.9mbs with is being 10mbs for most of the time. My PC is using a wireless connecting aswell. Does anyone know what to do on my pc to get the speed up?
1 REPLY 1
Hero
First take is the PC is connecting at 2.4Ghz, max speed would be about 50 down with a good signal and the S22 is connecting at 5Ghz hence the better speeds.
Use the link below to speed test the service to a Router mode Hub(3/4/5) + your device.
The speed at the Hub should reflect your subscription.
The speed any WiFi device draws data at is limited by its data needs and technical abilities.
