@dylanc533 wrote:
I don't actually no they both have very different things on them. I'm puzzled as well as I was getting full gigabit speeds at our old address and I can't think of anything that I've changed or installed. Is there anything you would suggest to look out for?
If you go into task manager then startup you'll see several processes you can disable.
You'll need to try each one, with a reboot each time, to find the offender.
Another thing you can do is action a speed test with task manager open and see what network / CPU resources are being the used by active applications.
