on 14-12-2021 16:44
Is anyone running a Hub 5 on the 1gig connection utilizing the 2.5Gbps port and as an example a 2.5Gbps port on a pc? if so what speeds are you getting? Would I see much more than what I have currently wired 920Mbps down and 52Mbps up with a TPlink Ax6600.
Also does anyone have an idea on the speed with a Hub 5 router in modem mode and using another router that has a 2.5Gbps port aswell.
14-12-2021 16:55 - edited 14-12-2021 17:00
@Roundy84 wrote:Is anyone running a Hub 5 on the 1gig connection utilizing the 2.5Gbps port and as an example a 2.5Gbps port on a pc? if so what speeds are you getting? Would I see much more than what I have currently wired 920Mbps down and 52Mbps up with a TPlink Ax6600.
As per the VM site you will see around 1086 - 1143 Mbps on one device
https://www.virginmedia.com/shop/broadband/speeds
Of course this depends on the capability of the device itself!
I've seen the below using other methods of getting full speed on one device:
My question would be do you really need it?
Faster broadband connections are designed to be used across multiple devices concurrently.
on 15-12-2021 10:45
I'm just curious how much if any, my speed would increase with everything using a 2.5Gbps port end to end and future scalability.
15-12-2021 11:01 - edited 15-12-2021 11:02
@Roundy84 wrote:I'm just curious how much if any, my speed would increase with everything using a 2.5Gbps port end to end and future scalability.
Well you are currently limited to 940Mbps through your third party router.
With the HUB 5 on 1gig you'll potentially see 1086 - 1143Mbps.
VM are in trials for 2.2Gbps.
Remember your broadband speed is shared between all your devices.
