lisamidd76
Just joined
Hub 4
haveing nothing but trouble  with the hub4 keeps disconnecting cant play online games had 2 engineers  out cant find what is wrong with it but once they have bin its fine for a day then starts playing up again my son works from home and now the bosses are saying they might have to let him go because off this as he works for the online banking side off things looking to fine a new intnet provider  now just had enough off this its bin going on since march
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Hub 4
Firstly, they can't let him go, that would be illegal.
Lets have a look to see what is happening ...
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
  • 15.93K
  • 688
  • 1.56K
Re: Hub 4
Use the hub in modem mode and get a wireless router with 1Gb ports.
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Re: Hub 4
To rely on a residential services for a business esp if he can get in hot water for downtime is not ideal and something VM did not allow in the past.
Advise you look at a dedicated line but that costs £££ (not saying you should have issue with VM though as it should work).
