stedav25
  • 7
Message 1 of 5
Hub 4 upload speed
Hi, recently upgraded to the Hub 4. On doing speed tests results for upload speed are no where near what I used to get on hub 3. I’ve tried resetting hub etc. checked connections n usual power downs. Hub 3 I was getting consistent 36mbps upload. Hub 4 is erratic and getting mixed results, I think closest to old hub 3 speed was 31mbps. Any ideas? Thanks Stephen
Tags (1)
  • 5.93K
  • 495
  • 1.5K
Message 2 of 5
Re: Hub 4 upload speed
Post your Hub stats please, power levels, Pre and PostRS errors and Network log.   Once done we can comment
Akua_A
  • 3.64K
  • 88
  • 242
Message 3 of 5
Hi @stedav25,
Welcome back to our community forums.
Sorry to hear you have been experiencing issues with your speeds since your hub 4 upgrades. This is certainly not ideal and we want to best help. Are you able to post the information requested by @Adduxi, so we can best look into this and help?
Akua_A
stedav25
  • 7
Message 4 of 5
Hi, is this correct? Thanks
John_GS
  • 13.38K
  • 681
  • 1.24K
Message 5 of 5
Hi stedav25,
Thanks for coming back to us.
Can you please check that the coax cables are securely connected to the Hub 4, to any splitters that are in use and to the wall socket.
Once the cables have been checked, the Hub needs to be rebooted. The Hub can be rebooted by using the button/switch at the back of the Hub or by turning the Hub off from the mains then turning it back on. Let me know if this fixes the issue
Best,
John_GS
