Hobnobs
  • 16
Message 1 of 21
Hub 4 unstable speeds
I do fancy faster speeds so please help me. I’ve had speeds varying from less than 1 to over 105Mbps. I’ve been sent a new hub3 then just today a technician visited and fit a hub4. He admitted it was unstable and said tech would monitor for the next couple of days. Issue is both wired and wifi even with cat 6 cable
PLEASE push whatever buttons you need to. It’s embarrassing giving a lecture and ending up in the waiting room because of unstable internet connection
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 21
Re: Hub 4 unstable speeds
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Hobnobs
  • 16
Message 3 of 21
Hobnobs
  • 16
Message 4 of 21
despite hub 4 it really seems to be a very inconsistent speed. Does the above graph mean anything?
  • 16.26K
  • 710
  • 1.6K
Message 5 of 21
Do a live boot of Ubuntu and do a speed test
https://ubuntu.com/download/desktop
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 21
What speed do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Hobnobs
  • 16
Message 7 of 21
 this shows ranges from 21 to 99Mbps all wired with cat 5
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 21
Can you log in to the Hub Settings and navigate to the Connected Devices page.
On that page what is the connection speed for the device with cable connection that you did the speed checks with ?
Hobnobs
  • 16
Message 9 of 21
Device name
MAC address
IP address
Speed (Mbps)
Connected to
Lisas-iPad
24
Wi-Fi 2.4G VM5774548
amazon-846a6ee2d
24
Wi-Fi 5G VM5774548
HP8D3723
300
Wi-Fi 5G VM5774548
unknown
6
Wi-Fi 5G VM5774548
unknown
6
Wi-Fi 5G VM5774548
Neils-Galaxy-Note10-5G
24
unknown
175.5
Wi-Fi 5G VM5774548
unknown
175.5
Wi-Fi 5G VM5774548
Neils-iPad
195.1
Wi-Fi 5G VM5774548
amazon-1ea5bfad0
6
Wi-Fi 5G VM5774548
Lisas-Galaxy-S9
24
Neil-PC
1000
Ethernet
Hobnobs
  • 16
Message 10 of 21
Device name MAC address IP address Speed (Mbps) Connected to
Lisas-iPad  6.5Wi-Fi 5G VM5774548
amazon-846a6ee2d  162Wi-Fi 5G VM5774548
HP8D3723  300Wi-Fi 5G VM5774548
unknown  6Wi-Fi 5G VM5774548
Neils-Galaxy-Note10-5G  6Wi-Fi 5G VM5774548
unknown  175.5Wi-Fi 5G VM5774548
Neils-iPad  263.3Wi-Fi 5G VM5774548
amazon-1ea5bfad0  6Wi-Fi 5G VM5774548
Lisas-Galaxy-S9  58.5Wi-Fi 5G VM5774548
Neil-PC  1000Ethernet
