Waynep1977
  • 12
Message 1 of 19
Hub 4 slowing down
I have the hub 4 with a 1 Gigb internet. My speeds where 80mb wireless. Just picked up a dlink gaming router and on the dlink app the speed from the hub to the router is 120mb. I only picked the router up to try and fix speeds. Tried all the rebooting and the hub is in modem mode. I'm at a loss. Thanks
Tags (1)
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Message 2 of 19
Re: Hub 4 slowing down
What was/is the Samknows built in App speed (not sure if it works in Modem Mode)?
https://samknows.com/realspeed/
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 3 of 19
yes that's it, doesn't work in modem mode.
My Broadband Ping - spgray
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Message 4 of 19
Hmm are you also the OP?
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 5 of 19
are you replying to me?
i was replying to your question by confirming that is indeed the link and it doesn't work when in modem mode.
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Message 6 of 19
OK, I thought you were OP on another account.
Waynep1977
  • 12
Message 7 of 19
Thanks for the replys. I noticed that by unplugging for a while my speed goes back to normal bit then 2 days later the speed drops.
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Message 8 of 19
This may be the fix,  😂
Waynep1977
  • 12
Message 9 of 19
As daft as it sounds that could be the only answer that would work lol
Anonymous
Not applicable
Message 10 of 19
Could you access the HUB using http://192.168.100.1 and post the 'Downstream', 'Upstream', and 'Network log' data?
