Digsee
Hub 4 slow
I recently upgraded to Hub 4. The first day was pretty quick nearly 300mbps but now it is averaging 80mbps which is much slower than old system. Have tried reset but still slow. Any ideas?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Hub 4 slow
What is your contracted speed ?
How are you checking the speed - Wi-Fi or ethernet connected device ?
Digsee
Re: Hub 4 slow
Thanks for reply but I have now been informed by Virgin to check speed using https://samknows.com/realspeed/ since this is compatible with Hub 4. This shows I am in fact getting good speeds unlike the Speedtest app I was using. So this is now resolved.
