jinks85
Hub 4 slow speeds
We received a free upgrade to Hub4 and decided to take it up due to the improved WiFi reliability. Not only is the WiFi still unreliable my wired speed has now dropped massively and we get between 3-15mbps instead of the 100mbps we pay for. Wishing I'd stayed with the old hub3. Can anyone suggest why this is happening?
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Hub 4 slow speeds
What speed do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
