rtim
  • 6
Message 1 of 11
Hub 4 slow speeds and intermittent connection
No connection multiple times this morning, currently connected but speed tests showing ~20/30mbps for a
Network diagnosis tool showing 'Your home network has a few problems.', Online service status test unavailable -  'Unfortunately we can't run a diagnostic test on your Hub 4 yet. But, we're working on it so you'll be able run one soon.' and unable to get through to anyone on the phone.
I have tried restarting the hub and leaving for 10 minutes.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 11
Re: Hub 4 slow speeds and intermittent connection
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
rtim
  • 6
Message 3 of 11
Thanks, Mike. Service status of 'No known issues' and I've completed the other steps below.
My BQM
3.0 Downstream channels
71867500002.59999838.983261QAM2567
11387500003.70000140.366287QAM2561
21467500003.50000040.366287QAM2562
31547500003.09999840.946209QAM2563
41627500003.09999840.946209QAM2564
51707500002.70000140.366287QAM2565
61787500002.70000140.366287QAM2566
81947500002.40000240.366287QAM2568
92027500002.40000238.983261QAM2569
102107500002.20000138.983261QAM25610
112187500002.40000240.366287QAM25611
122267500002.20000138.983261QAM25612
132347500002.09999838.983261QAM25613
142427500001.79999938.983261QAM25614
152507500001.59999838.983261QAM25615
162587500002.09999838.983261QAM25616
172667500002.00000038.983261QAM25617
182747500002.40000238.983261QAM25618
192827500002.29999938.983261QAM25619
202907500002.20000140.366287QAM25620
212987500002.70000140.366287QAM25621
223067500001.79999938.983261QAM25622
233147500001.59999838.983261QAM25623
243227500002.00000038.983261QAM25624
253307500001.79999940.366287QAM25625
263707500002.00000038.605377QAM25626
273787500002.09999838.983261QAM25627
283867500001.90000238.605377QAM25628
293947500001.29999938.983261QAM25629
304027500001.90000238.605377QAM25630
314107500001.70000138.983261QAM25631
7Locked000
1Locked8853330400
2Locked1866970500
3Locked9043863500
4Locked1927040500
5Locked1856184500
6Locked1771440800
8Locked185475200
9Locked154737300
10Locked188862400
11Locked246539000
12Locked184635800
13Locked185766300
14Locked217300000
15Locked183342000
16Locked218624500
17Locked172167700
18Locked182098100
19Locked153643500
20Locked6175902400
21Locked183813500
22Locked181264000
23Locked178161400
24Locked231364000
25Locked229157300
26Locked243997700
27Locked226790800
28Locked196929900
29Locked211759300
30Locked176276200
31Locked9249945800
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33864K1680QAM4096424
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33Locked 0.8265161310
rtim
  • 6
Message 4 of 11
3.0 Upstream channels
15370000047.0205995120 KSym/sec64QAM2
23940000046.2705995120 KSym/sec64QAM4
34620000046.7705995120 KSym/sec64QAM3
43260000046.0205995120 KSym/sec64QAM5
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
Sun 04/10/2020 21:14:044DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 04/10/2020 22:13:114DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 04/10/2020 22:54:244DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 04/10/2020 23:05:414DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 05/10/2020 00:12:414DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 05/10/2020 00:31:014DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 04:52:553SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 04:52:595Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 04:55:013Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 04:55:223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 04:55:326CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 04:55:373No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 04:55:386CM-STATUS message sent. Event Type Code: 4; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 04:55:383No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 04:55:506CM-STATUS message sent. Event Type Code: 23; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 04:55:513No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 05:00:413Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 05:00:413Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 05:00:433No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 05:01:273Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 05:01:273Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 05:01:483Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 05:01:483Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 05:03:065MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 23:35:093No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 09/10/2020 18:46:356CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 12/10/2020 00:32:434DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 13/10/2020 08:02:474DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 13/10/2020 09:32:333No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 13/10/2020 19:26:086CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 16/10/2020 08:13:534DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 16/10/2020 19:52:126CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 16/10/2020 22:59:484DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 17/10/2020 03:55:104DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 17/10/2020 16:30:166CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 21/10/2020 18:00:194DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 21/10/2020 19:07:496CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 22/10/2020 09:01:014DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 23/10/2020 00:01:474DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 26/10/2020 03:57:094DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 26/10/2020 06:03:413No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 26/10/2020 14:26:314DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 27/10/2020 00:55:574DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 27/10/2020 03:57:553No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 27/10/2020 09:34:446CM-STATUS message sent. Event Type Code: 2; Chan ID: 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 27/10/2020 09:34:453SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 11
The Hub stats are looking OK.
Just need to give the BQM time to develop to see what is happening on the WAN side.
rtim
  • 6
Message 6 of 11
Hi Mike, any updates? I had issues with very slow speeds this afternoon between 4-6pm GMT.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 11
Your >> BQM << is showing signs of utilisation issues.
You can try phoning in and tell them that your internet is very slow. DO NOT mention the BQM because it will not be in their script.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Emma_C
  • 8.28K
  • 512
  • 559
Message 8 of 11
Hi Rtim,
Very sorry for the issues you're having with the services at the moment and the delay in getting back in touch, we have been busier than usual.
I've had a look at the back end of things and it's all looking really good from here, can I ask if you're still having this issue?
If so please reboot the hub so we can get some more up to date data as it has been up some time and we'll run some further checks.
Emma_C - Forum Team
rtim
  • 6
Message 9 of 11
Hi Emma, I reset the box and realise I forgot to let you know.
I am still having intermittent issues. Especially noticeable in the evenings on video calls for work.
Thank you for looking into this,
Tim
rtim
  • 6
Message 10 of 11
Hi Emma,
Still having intermittent issues. Thank you for looking into this.
Tim
