johndm
  • 213
  • 17
Superfast
Message 1 of 5
Hub 4 drops to 94 meg port output UPDATE
There are a few threads about the same subject, so starting a new thread for an update
Using Hub 4 in modem mode with my own router
Hub 4 speed from Ethernet port crashes to 94 meg on 1 gig service.
Reboot or Ethernet cable unplug/re-plug required to restore 945 meg from Hub to router
Since getting an upgrade from 500 with Hub 3 to 1 gig with Hub 4, Ethernet speed out of Hub 4 was crashing to 94 meg every two to three days.
Although I was using a brand new flat cat 7 cable, I thought it was worth swapping to an Enterprise grade cat 8 which I had going spare. (Used the flat type for convenience)
Fingers crossed, had a solid connection for 6 days now, monitoring carefully.
Hope I'm not tempting fate posting 🙂
  • 35.13K
  • 3.42K
  • 6.69K
Message 2 of 5
Re: Hub 4 drops to 94 meg port output UPDATE
Probably just a dodgy connection on the ethernet connector - I have had a few ethernet cables "fail" on me over the years
  • 13.91K
  • 1.08K
  • 2.82K
Message 3 of 5
I’ve found flat Ethernet cables to be useless and will never use Cat7, Cat6a is just as good.
  • 20.5K
  • 828
  • 2.2K
Message 4 of 5
I wouldn't put it passed VM for the firmware to lower Tx power on the edge of causing a port link drop on low quality cables.
johndm
  • 213
  • 17
Superfast
Message 5 of 5
Full speed maintained for 9 days now, looks like the issue is defiantly linked to cheaper ethernet cables.
The same flat one worked fine on my 500 service for nearly 2 years
