  • 30
  • 6
Message 1 of 15
Hub 4 connection problems
I have been having a few issues where at times I am having to reboot my hub 4 due to web pages not loading properly or because my upload and download speeds are slow. Rebooting does seem to fix the issue for a while. I also had some T3 Timeouts  on all channels but disappeared when I rebooted the Hub
Do these stats look ok.
Capture 1.PNGCapture 2.PNGCapture 3.PNGCapture 4.PNGCapture 5.PNGCapture 6.PNG
  • 6.41K
  • 474
  • 840
Hero
Message 2 of 15
Re: Hub 4 connection problems
Your images are not showing because they need authorizing.
Can you load them to a hosting service then post the links on here please.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 30
  • 6
Message 3 of 15
I am not sure if this will work but here is a link
https://imgur.com/a/1r10VSc
  • 6.41K
  • 474
  • 840
Hero
Message 4 of 15
Excellent.
To my untrained eye I can see that your upstream QAMs are way out of kilter.
For a bit more evidence set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the Hub, it will take a few hours to get any kind of trend showing.
On here click the Link icon (2 link chain)
 In the URL box paste the link you copied and then click OK
Either phone it in or wait on here for one of the VM Staff to pick up the thread, someone should be along within a couple of days.
Don't bump your thread; it doesn't get answered any quicker.
Mike Robinson
  • 30
  • 6
Message 5 of 15
  • 6.41K
  • 474
  • 840
Hero
Message 6 of 15
Can you post a 'live' link to it ?
Link has just appeared.
It isn't looking too bad.
Mike Robinson
  • 30
  • 6
Message 7 of 15
Just a update my speed as dropped and I'm only getting 10Mb upload speeds when I usually get around 50Mb. My download speed as cut in half as well. Spoke to Virgin Media on the phone but didn't find them very helpful.
https://imgur.com/a/AW76jEZ
I'm sure the T3 Timeouts are not helping
  • 30
  • 6
Message 8 of 15
Still having issues with Speed and drop outs with T3 timeouts. This as been going on since March.
https://imgur.com/a/zamfpCj
  • 408
  • 20
  • 57
Fibre optic
Message 9 of 15
A technicain visit may be required on this one...
Hold tight and somebody should be around to help shortly.
Matt
If I've helped please let me know 🙂
10 years in Technical Customer Service, Construction Trades and Administration - Now I'm a Furloughed Chef
  • 605
  • 36
  • 93
Rising star
Message 10 of 15
I wouldn't worry too much about T3 timeouts.
What you should worry about are...
Low S/N ratio on some of your low frequency downstream channels
The 8dB variation in downstream signal levels from low frequency to high frequency channels
Upstream signal levels too high (the modem is having to shout to be heard)
Upstream modulation should be 64QAM not 8QAM - probably due to poor S/N ratio on upstream.
Engineer visit needed!
