Tazz
  • 534
  • 12
  • 81
Rising star
Message 1 of 8
Hub 4 Keeps randomly rebooting
Hello
My hub 4 has randomly started rebooting over the past few days. I cannot see any reason why its not hot and the fan has no dust in it.
Can a VM staff member check things on their end to see if they can see why?
Below are stats and logs:
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
3.0 Downstream channels
14110000003.338.6QAM2561
24190000002.938.6QAM2562
34270000002.839QAM2563
44350000002.839QAM2564
54430000002.839QAM2565
64510000002.439QAM2566
74590000001.638.6QAM2567
84670000001.239QAM2568
94750000001.439QAM2569
104830000001.838.6QAM25610
114910000001.638.6QAM25611
124990000001.538.6QAM25612
135070000001.739QAM25613
145150000001.938.6QAM25614
155230000001.939QAM25615
165310000001.739QAM25616
175390000001.839QAM25617
185470000001.939QAM25618
195550000001.839QAM25619
205630000001.638.6QAM25620
215710000001.438.6QAM25621
225790000001.438.6QAM25622
235870000001.538.6QAM25623
245950000001.439QAM25624
25603000000139QAM25625
266110000000.538.6QAM25626
276190000000.639QAM25627
286270000000.539QAM25628
296350000000.539QAM25629
306430000000.138.6QAM25630
31651000000-0.139QAM25631
Tazz
  • 534
  • 12
  • 81
Rising star
Message 2 of 8
Re: Hub 4 Keeps randomly rebooting
1Locked38.60537700
2Locked38.60537700
3Locked38.98326100
4Locked38.98326100
5Locked38.98326100
6Locked38.98326100
7Locked38.60537700
8Locked38.98326100
9Locked38.98326100
10Locked38.60537700
11Locked38.60537700
12Locked38.60537710
13Locked38.98326100
14Locked38.60537710
15Locked38.98326100
16Locked38.98326110
17Locked38.98326110
18Locked38.98326130
19Locked38.98326120
20Locked38.60537730
21Locked38.60537720
22Locked38.60537710
23Locked38.60537710
24Locked38.98326140
25Locked38.98326120
26Locked38.60537720
27Locked38.98326120
28Locked38.98326110
29Locked38.98326110
30Locked38.60537740
31Locked38.98326120
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159964K1880QAM4096728
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked4101310972120
3.0 Upstream channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
12580000038.35120 KSym/sec64QAM6
23260000038.35120 KSym/sec64QAM5
33940000038.35120 KSym/sec64QAM4
44620000038.35120 KSym/sec64QAM3
3.0 Upstream channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
Network LogTime Priority Description
Thu 01/01/1970 00:01:274Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 20/06/2021 19:11:325MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 20/06/2021 19:34:285DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 23/06/2021 09:12:355MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 23/06/2021 09:24:515DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 3 of 8
Hub stats look fine - is it wireless or wired devices that you are noticing this on?
Tazz
  • 534
  • 12
  • 81
Rising star
Message 4 of 8
Both, it just did it again now and the hub uptime resets each time too: System up time : 0 days 0h:14m:29s
latest events:
Wed 23/06/2021 16:18:495MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 23/06/2021 16:31:045DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
https://www.speedguide.net/faq/what-does-the-mimo-event-mimo-log-message-mean-393
Tazz
  • 534
  • 12
  • 81
Rising star
Message 5 of 8
Just to also confirm I have tried a pinhole reset a couple of days ago.
Corey_C
  • 3.94K
  • 214
  • 328
Message 6 of 8
Thanks for your posts and updates, Tazz,
How has the connection been since your post?
Cheers,
Corey C.
Tazz
  • 534
  • 12
  • 81
Rising star
Message 7 of 8
Funny you ask because I think it was the wireless link from the CCTV camera. I have changed it to a spare VM pod for now and so far it has been stable lets give it a week.
Corey_C
  • 3.94K
  • 214
  • 328
Message 8 of 8
Thanks for your reply and update, Tazz, keep us posted.
Cheers,
Corey C
