x3noc
  • 16
Message 1 of 18
Hub 4 Jitter, Gaming Lag, VOIP unusable on WIRED connection
Two day old Hub 4 installation.
Speedtests all show increase in speed etc
VOIP / Teams is dreadful - constant robotic voice and others are getting dropouts from me.
Gaming is unusable - lag and jitter all over the place. I just teleport from one place to another.
Devices plugged into the router (Raspberry Pi, Netgear Router) are not being activated by the switch. If i reboot the router these device then need a reboot in order to become recognised by the Hub 4 router.
All in all feels like a downgrade to me...
If i eventually uncover the phone number to call them i will...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 18
Re: Hub 4 Jitter, Gaming Lag, VOIP unusable on WIRED connection
You need to post your Downstream stats and Network Log.
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 18
You can contact VM to report your problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
Tom_F
  • 2.8K
  • 160
  • 347
Message 4 of 18
Hi x3noc, thanks for getting in touch.
Apologies for the problems you've had since your Hub 4 was installed. I was able to check things over from here and all appears to be fine. As advised by MikeRobbo above can you please post your Hub/network connection details so we can check to see if there is a problem there? If you're unsure how:
In your browser’s URL box type in  http://192.168.0.1  (or http://192.168.100.1 - if in modem mode) and hit return. Click on the “router status” icon at top right (SuperHub2) or the text at bottom-middle of first page up (Hub3) and then copy/paste 3 full sets of data onto here – from the downstream, upstream, &  network logs pages. Please don’t include personal data or MAC addresses -  if you copy/paste the data the forum software should blank them out for you.
A BQM is a great shout as well if possible, please keep us posted with how you get on.
Tom
x3noc
  • 16
Message 5 of 18
BQM Link added
x3noc
  • 16
Message 6 of 18
Downstream and log - Upstream was already posted.
Also i'm still alarmed that i'm having to reboot devices after the hub is rebooted in order for the swtich in the router to recognise them.
I did try to put my old router back on but its already been disabled. I'd like roll back to my Hub 3 if that can be arranged, i spend almost every day in Teams calls and simply cannot work like this.
x3noc
  • 16
Message 7 of 18
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 8 of 18
Can you copy and paste your Hub stats please, those screen grabs are nigh on illegible.
Andruser
  • 5.54K
  • 971
  • 2.28K
Message 9 of 18
Can you copy <as selected text> and paste <as formatted text> your Hub stats please, those screen grabs are nigh on illegible.
x3noc
  • 16
Message 10 of 18
3.0 Downstream channels
253310000003.90000240.366287QAM25625
11390000007.69999740.366287QAM2561
21470000007.19999740.946209QAM2562
31550000006.90000240.946209QAM2563
41630000006.69999740.946209QAM2564
51710000006.40000240.946209QAM2565
61790000006.30000340.366287QAM2566
71870000006.09999840.366287QAM2567
81950000005.90000240.946209QAM2568
92030000005.80000340.946209QAM2569
102110000005.40000240.946209QAM25610
112190000005.30000340.946209QAM25611
122270000005.00000040.366287QAM25612
132350000005.00000040.366287QAM25613
142430000004.80000340.946209QAM25614
152510000004.59999840.946209QAM25615
162590000004.40000240.366287QAM25616
172670000004.30000340.946209QAM25617
182750000004.59999840.366287QAM25618
192830000005.19999740.946209QAM25619
202910000005.50000040.366287QAM25620
212990000005.30000340.946209QAM25621
223070000004.69999740.946209QAM25622
233150000004.30000340.366287QAM25623
243230000004.00000040.946209QAM25624
263390000003.50000040.366287QAM25626
273470000003.29999940.366287QAM25627
283550000003.00000040.366287QAM25628
293630000002.90000240.366287QAM25629
303710000002.90000240.946209QAM25630
313790000002.79999940.366287QAM25631
25Locked000
1Locked109421000
2Locked110917400
3Locked98623700
4Locked100280900
5Locked110297700
6Locked101121100
7Locked97102300
8Locked101502600
9Locked104130000
10Locked107067300
11Locked93212800
12Locked94368500
13Locked98483200
14Locked97846800
15Locked99046400
16Locked55598600
17Locked58448800
18Locked51943600
19Locked57003700
20Locked41597500
21Locked56515600
22Locked52829200
23Locked45606600
24Locked119278000
26Locked122318800
27Locked111783000
28Locked116030100
29Locked118873900
30Locked131378300
31Locked22602970000
