Adrian-29_M
  • 13
Hub 3 speed
Hello anyone knows what it’s the top speed of the HUB 3 ??? Can you let me know please. Thank you
DJ_Shadow1966
  • 7.12K
  • 1.36K
  • 2.02K
Re: Hub 3 speed
Hello
The hub 3 is given out on all packages upto 500mbps.
In relation to what ? i.e. Wireless or Wired ?
If it wired that it is capable of the speed that your package is depending on the Ethernet cable connected which should be Cat 5e or above.
If it is wireless then that will depending on the device, the wireless band that it is connecting too i.e. 2.4Ghz around 60mbps, 5.0Ghz around 200mbps, depending on distance, interference and makeup of the premises.
Regards Mike
