Sukester
  • 6
Hub 3 issues
Been having slow download/upload speeds. Red light is on on my Hub 3 - followed all online advice switched off and on several times.
Light still red speeds still slow.
Messaged, and been on a call now for 30+ minutes.
Can anyone help?
Andrew-G
  • 6.04K
  • 1.07K
  • 2.54K
Re: Hub 3 issues
A red light indicates over heating.  You can try a pinhole reset (but only if you haven't done that already), but there seems to be a batch of Hub3s that are having these problems.  Realistically you'll probably need a replacement hub, but try the pinhole reset first.  Until such time as this is sorted then you're probably OK to keep using it, but as a precaution I wouldn't leave it powered on overnight until it starts behaving, or you get a replacement sorted.
Sukester
  • 6
Re: Hub 3 issues
Yep - i found that advice but it is in a cool room and stood upright with nothing around it causing blockage to the vents. After the pinhole reset the light is now yellow.
Thanks for your advice - looks like I somehow need to get in touch with someone at Virgin who can help - which is easier said that done!
Andrew-G
  • 6.04K
  • 1.07K
  • 2.54K
Re: Hub 3 issues
Oh dear, another instance of the Yellow Light of Doom.  I'll flag your post for the staff, it looks like you need a new hub.  Be aware that if there's also noise or power problems on the line, then you may STILL need a technician visit to get your full speeds restored, but replacing a faulty hub is step one.
Paul_DN
  • 5.78K
  • 340
  • 611
Re: Hub 3 issues
Hi Sukester,
Thanks for reaching out to us in our community and welcome, I am sorry to see you are having connection issues and only have a yellow light, I have had a look our end and it looks like you may have alrady sorted this out by ordering a new router.
Paul.
Sukester
  • 6
Re: Hub 3 issues
So i had a new hub arrive and i have the same problems - plenty of resets later - and still ridiculously low speeds and red or yellow light issues intermittently.
I'm at the point now where paying for a 200mbps service and getting on average 26mbps is atrocious and affecting my work so looks like i have no choice but to leave and at least pay for a slower speed from a more reliable source.
