Gregg11001
  • 26
Message 1 of 20
Hub 3 getting hot and speed issues
Hello,
Can you please advise on broadband slowing down, interruptions in service, not getting anywhere near the speed I am paying for (500 mb/sec). Now I find my Hub 3 is getting quite hot, was never like it is now.
Thank you,
Greg
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 20
Re: Hub 3 getting hot and speed issues
Is the Hub overheat light illuminated ?
If the temperature is worrying you it should be switched OFF until the problem is investigated.
If you are happy to continue can you please ...
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Gregg11001
  • 26
Message 3 of 20
Hello,    Did you receive the info posted about router readings. Would not carry on because over 20,000 characters.  Can send by email if I have an address which you can view.
Greg
Gregg11001
  • 26
Message 4 of 20
Will not send info due to too many characters. Have clicked post twice- same thing
Anonymous
Not applicable
Message 5 of 20
You have to post the data into multiple posts. You also have to click 'Post' twice on occasion.
Gregg11001
  • 26
Message 6 of 20
30/07/2020 15:51:31
critical
30/07/2020 09:04:16
notice
DHCP Renew - lease parameters tftp file-Vcb573b2ee9a9587e.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/07/2020 09:04:16
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/07/2020 22:34:51
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/07/2020 19:58:5
critical
29/07/2020 12:05:29
Error
26/07/2020 19:53:58
critical
26/07/2020 07:10:5
notice
26/07/2020 07:10:5
Error
26/07/2020 07:02:59
Error
26/07/2020 07:01:12
critical
25/07/2020 16:09:19
Error
25/07/2020 01:58:18
critical
25/07/2020 01:08:37
Error
20/07/2020 11:44:10
critical
20/07/2020 11:03:29
notice
20/07/2020 11:03:29
Error
20/07/2020 10:44:58
Error
20/07/2020 10:44:56
critical
19/07/2020 15:22:11
Error
Gregg11001
  • 26
Message 7 of 20
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
467000000
0
37
256 qam
32
2
219000000
0.5
37
256 qam
11
3
227000000
0.5
37
256 qam
12
4
235000000
0.5
37
256 qam
13
5
243000000
0.2
37
256 qam
14
6
251000000
0
37
256 qam
15
7
259000000
0
37
256 qam
16
8
267000000
0
37
256 qam
17
9
275000000
0
37
256 qam
18
10
283000000
0
37
256 qam
19
11
291000000
0.2
37
256 qam
20
12
299000000
0.2
37
256 qam
21
13
307000000
0.2
37
256 qam
22
14
315000000
0.2
37
256 qam
23
15
323000000
0.4
37
256 qam
24
16
411000000
0.9
37
256 qam
25
17
419000000
0.7
37
256 qam
26
18
427000000
0.4
37
256 qam
27
19
435000000
0
37
256 qam
28
20
443000000
0
37
256 qam
29
21
451000000
0
37
256 qam
30
22
459000000
0
37
256 qam
31
23
475000000
0.2
37
256 qam
33
24
483000000
0.4
37
256 qam
34
Gregg11001
  • 26
Message 8 of 20
Router status
Refresh data
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700036
4.05
5120
64 qam
2
2
39399996
3.9
5120
64 qam
4
3
46199986
3.9
5120
64 qam
3
4
60300004
4.05
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Gregg11001
  • 26
Message 9 of 20
Thank you for your advice and help.
Anonymous
Not applicable
Message 10 of 20
On the downstream tab there is another table of data at the bottom. Could you post that please?
