russelluk
  • 26
Message 1 of 18
Hub 3 - connection drops and slow speeds
HI
I have a virgin Hub 3, I have been having drops and slow speeds for some time now I have just run a test on my hub and it says that I have slow wireless move your device closer to the hub.
Well my device is about 1 foot away from my Hub I have tried reboots and resets to the hub no difference to my speeds and drop out.
Will a new hub help with this problem or is it my line that is at fault
thanks
Russell
conman33158
  • 1.68K
  • 134
  • 364
Super solver
Message 2 of 18
Re: Hub 3 - connection drops and slow speeds
If you’re getting good speed on a wired connection and poor wifi speed and range you would probably be better of investing in a decent third party router, that way you can put the Virgin Hub into modem mode and let the router deal with all the traffic. This would give you better wi-fi coverage and if you go for the likes of a wi-fi 6 capable router you would get better speeds. There are loads of options from Asus, TP Link etc and seeing as the VM Hubs are well known for their lack of wi-fi capabilities you would be better of using your own equipment. I know it's a case of having to spend money that you shouldn't have to, but it really is worth it and gives you a better all round stable internet experience.
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
  • 6.09K
  • 512
  • 1.57K
Message 3 of 18
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as some small faults are not listed on the VM status page.
Try a full factory reset on the Hub as below;
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
Once done post the power levels and network log from the Hub.  Do not use screenshots, just copy and paste into several posts.  Consider setting up a BQM to record your incoming circuit.  www.thinkbroadband.com/ping
You could also try splitting the wifi SSID;
• Access your Hub by navigating to 192.168.0.1
• Login with the default login info (on base of Hub) unless you've already updated it.
• Go to Advanced Settings > Wireless > Security
• Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID), suggest append _2 to the end.
• Repeat for the Wireless Frequency 5GHz, suggest append _5 to the end and click on Apply changes
• Try to avoid spaces and periods in the SSID names as they can cause issues with certain devices.
russelluk
  • 26
Message 4 of 18
here is my hub settings hope this helps means nothing to me
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
330750000
-3
40
256 qam
25
2
234750000
-2.5
38
256 qam
13
3
242750000
-3.2
38
256 qam
14
4
250750000
-3
38
256 qam
15
5
258750000
-3.7
38
256 qam
16
6
266750000
-3.2
40
256 qam
17
7
274750000
-3.5
38
256 qam
18
8
282750000
-3
38
256 qam
19
9
290750000
-3.5
38
256 qam
20
10
298750000
-2.9
38
256 qam
21
11
306750000
-2.7
40
256 qam
22
12
314750000
-2.7
38
256 qam
23
13
322750000
-2.7
38
256 qam
24
14
338750000
-2.7
38
256 qam
26
15
346750000
-3
38
256 qam
27
16
354750000
-2.5
40
256 qam
28
17
362750000
-3.2
38
256 qam
29
18
370750000
-2.9
38
256 qam
30
19
378750000
-3.4
38
256 qam
31
20
386750000
-2.5
40
256 qam
32
21
394750000
-3.7
40
256 qam
33
22
402750000
-3.2
40
256 qam
34
23
410750000
-3.7
38
256 qam
35
24
418750000
-3.9
38
256 qam
36
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
489
2604
2
Locked
38.9
544
2085
3
Locked
38.9
483
1867
4
Locked
38.9
476
1692
5
Locked
38.9
489
1707
6
Locked
40.3
509
1694
7
Locked
38.6
499
1878
8
Locked
38.9
476
1772
9
Locked
38.9
436
2018
10
Locked
38.9
503
2204
11
Locked
40.3
542
2154
12
Locked
38.6
479
2352
13
Locked
38.9
512
2646
14
Locked
38.9
575
2292
15
Locked
38.6
543
2602
16
Locked
40.3
485
2728
17
Locked
38.9
554
2431
18
Locked
38.9
606
2363
19
Locked
38.9
609
2365
20
Locked
40.9
720
2255
21
Locked
40.3
741
1903
22
Locked
40.3
667
2088
23
Locked
38.9
684
2086
24
Locked
38.6
741
1882
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700000
49.5
5120
64 qam
2
2
39400000
48
5120
64 qam
4
3
46200000
49
5120
64 qam
3
4
60300000
49.5
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
foA,.iyewrkldJKDHSUBsgvca6983
SFID
14825
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
14824
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
Travis_M
  • 3.89K
  • 140
  • 287
Message 5 of 18
Hi @russelluk
Thanks for posting on our community forum!
How are you getting on today? Are you experiencing these issues via both wired and wireless connections at the same time?
Travis_M
russelluk
  • 26
Message 6 of 18
Hello
Yes I am getting drops with both wifi and ethernet I am getting the correct speed for ethernet around 340 mbs but wireless is sometimes as low as 40 Mbs.
Even though the wireless devices are just feet away. I think my main concern is the disconnections I get it is rather annoying when your watching Netflix Disney and so on.
Russell
Zak_M
  • 6.12K
  • 315
  • 545
Message 7 of 18
Good afternoon @russelluk
Thank you for coming back to us.
I have managed to locate your account via your forum information, I have run some additional checks on your services & I can see that we are going to need an engineer to visit and put it right.
I am going to pop you over a PM so that we can get some account information.
Kind regards,
Zak_M
Zak_M
  • 6.12K
  • 315
  • 545
Message 8 of 18
Thank you for providing me with that information via PM.
I have arranged for the engineer to attend, for the time, date & to make any further amendments please visit your My Virgin Media account
Please do let us know how things go with the appointment.
Kind regards,
Zak_M
russelluk
  • 26
Message 9 of 18
where do i find the appointment in my account ?
Russell
russelluk
  • 26
Message 10 of 18
Thanks found it
Russell
Thanks for all the support
