  • 391
  • 18
Up to speed
Message 1 of 8
Hub 3 Speed Honeymoon Over??
Hub 3 installed recently following problems the my 2.
Initial speeds for the first few weeks for my M200 account were 200+ Down and 20+ Up.
Last few days it's dropped dramatically to between 2 and 3 Down. Up has been ok.
Here are the power levels.....
Speedtest 29-01-20.jpg1. Downstream 1-10.jpg2. Downstream 11-21.jpg3. Downstream 22-23.jpg4. Upstream.jpg
M200 Fibre Broadband
Talk More Anytime Phone
Maxit TV
V6
500GB TIVO
Pixel C
Google Pixel 3XL
Sony Bravia 4K Smart Android TV
  • 1.32K
  • 190
  • 630
Message 2 of 8
Re: Hub 3 Speed Honeymoon Over??
Call it in to customer service as a fault - could be a known area fault or probably you have a damaged connection between yourself and the street cabinet. Downstream S/N ratios are too low on many of the channels and your upstream power levels are looking a bit iffy - my money would be on a bad joint.
  • 391
  • 18
Up to speed
Message 3 of 8
Thanks for the quick response......I'll update as and when.
Maxit TV
V6
500GB TIVO
Pixel C
Google Pixel 3XL
  • 391
  • 18
Up to speed
Message 4 of 8
A few weeks on and the speed has been 200+ down and 20+ up without any calls to Customer Service.
So I'm none the wiser...............
Maxit TV
V6
500GB TIVO
Pixel C
Google Pixel 3XL
  • 12.44K
  • 859
  • 3.72K
Message 5 of 8
Did an engineer come?
  • 1.32K
  • 190
  • 630
Message 6 of 8
It’s entirely possible that there was a fault in the street cabinet which they’ve now dealt with and consequently fixed your (and anyone else connected to the same cabinet) speed issue.
  • 391
  • 18
Up to speed
Message 7 of 8
Didn't have an Engineer visit. "Sorted itself", as far I was concerned.
Maxit TV
V6
500GB TIVO
Pixel C
Google Pixel 3XL
  • 497
  • 25
  • 47
Message 8 of 8
Hi bds1958
Thanks for your reply.
Glad to hear that speeds have been better now - I've checked the account for you to make sure and I can see that there aren't any faults in your area or with the equipment. It looks like there are some wireless issues however, which can be resolved using our Connect App  where you can scan each room for wireless issues and optimize the signal for each room/device.
We also have great information here that you can use to ensure you're getting the best out of your wireless connections.
Let us know if you're having any other issues 🙂
Hollie_B
Hollie - Forum Team
