Jono1990
Message 1 of 5
Hub 3 - 600mb plan
I have been having speed issues for a year now. engineer has been out and can't seem to see what the issue is. We have had 2 new replacement hub 3's and we still get no more than 80mb (this is stood right next to the router). Anyone else had these issues? They don't seem to want to swap it for a hub 4 even though we are not getting the minimum of 340mb
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 5
Re: Hub 3 - 600mb plan
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 5
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 5
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Please do not use screen shots.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Jono1990
Message 5 of 5
15370000040.8512064 qam1
23260000039.8512064 qam4
34620000039.8512064 qam2
43940000040.3512064 qam3
3ATDMA0000
4ATDMA0000
