Huawei issues with wifi speed ?
I have a Huawei P30 Pro which i've had for some time now. I've been back and forth to Virgin saying my wifi speed is terrible, I get around 2-7mbs/s instead of the 210mbs/s I get from my ethernet connected PC.
Today I tested with a friends phone on my wifi to realise they had 200mb/s.. I tested another phone and a tablet and then another tablet.. all of which are getting full speeds. I have no idea why the Huawei isnt getting this kind of speed, is it a router setting ? I have forgot the network and reset my network settings on my phone but with no avail. Is anyone else having problems with their Huawei ?
I have tried connecting via 5Ghz and 2.4Ghz, did a full modem reset, put it in modem mode then router mode.. I am baffled.
  • 6.63K
  • 494
  • 870
Legend
Re: Huawei issues with wifi speed ?
You may be as well refining your wifi management, it might not fix your problem but will certainly help keeping track of your wifi frequencies.
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name > Add 5 to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all you WiFi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Thanks for the reply Mike, I forgot to mention i've tried that also with no luck. The wifi varies now and again and once or twice i'll get 20-30mb/sec but majority of the time its 2-7mb/s
  • 113
  • 8
Up to speed
Have you tried your phone on another WiFi network?
I've only tried it at my parents house who have virgin media also, the hospital WiFi where I work is painfully slow so that doesn't indicate anything to me. At my parents it's the same speed, they also have a superhub 3.0
  • 6.63K
  • 494
  • 870
Legend
Have a look >> HERE <<
Mike Robinson
