on 01-06-2023 17:18
I got an e-mail this morning that the new upload speed is now available and all I have to do is switch off the router
wait 10 seconds and switch it back on then check the speed
So I did this....twice
and the upstream service flow on my hub5 is still the same at 38520000 and speed test hasn't changed at all
Do I need to do anything else? Contact customer services or have I done it wrong somehow?
on 01-06-2023 19:31
Sounds like the PR emails have gone out ahead of the engineering changes.
on 04-06-2023 11:17
Hi @Blakey47 👋,
A warm welcome to our Community Forums and thanks for your post.
Your broadband upload speed has been given a boost and the speed updates automatically after a reboot.
I have checked our systems and can see you have since reported an issue with your broadband - services being offline and a technician appointment has been arranged.
Let us know how it goes at the visit so we can offer further support if required.
on 05-06-2023 17:52
Hi, the lovely engineer has been and made an adjustment to the levels but however, even though its been rebooted several times now the speed increase still doesn't show
Maybe as someone has suggested the email has gone out before the actual speed increase has been activated although RealSpeed Samknows shows my package as 500x50
on 05-06-2023 18:18
Same boat, that after numerous reboots still no upload boost. The account details in MyVirginMedia account show my package as 500/50, but still only getting between 26 and 32 on uploads.
It would be good if somebody from VMO2 could confirm if the boost was meant to be instant, or if it is a delayed roll out. If it is a delayed roll out why was the email sent out telling us to reboot?
on 05-06-2023 20:32
I did get 100mb down last week but only getting 49mb now, when I check the router the max upstream has been rolled back to what it was previously... very weird.. also got the email telling me I've been upgraded... although I knew about it a couple weeks before and rebooted a while back and it doubled.
on 07-06-2023 20:50
Hi @Blakey47,
Thank you for coming back to us. Have you been able to run a wired speed test on your broadband Hub to see what speeds you're getting?
Have you taken a look at our Speed Up page as well to see if this can help?
Please take a look and let us know how you get on so that we can help if needed.
Thank you.
on 07-06-2023 20:53
The engineer did a test when he attended and got 36mb upload on my wired connection
on 08-06-2023 15:08
I also got the email a week ago, and have been doing daily hub reboots since. Still no new network logs that indicate a new config file has been downloaded, and the Router status page for Upload still shows Max Traffic Rate as: 38520000 still so no point running speed tests until the hub gets a new config to allow a rate of over 50,000000
on 10-06-2023 17:23
I'm so sorry to hear this @Blakey47 and thank you for popping back to us, can I ask what the engineer stated when they were back?
Are these tests across wired or WiFi connections? Is download showing as changed at all?
