19-09-2022 17:56 - edited 19-09-2022 18:01
Hello, I am experiencing latency and packet loss on my Gig1 connection with the Hub 4. This results in it being unusable for latency sensitive applications such as gaming.
I have checked the router status and it seems there is noise on the upload channel that is likely the problem as one of the channels keeps intermittently changing from 64QAM to 32QAM and also could be a power level issue too:
The router status below is after the Hub 4 lost connection so all the uncorrectable packets are reset to 0.
25 | 330750000 | 10.300003 | 40.946209 | QAM256 | 25 |
1 | 138750000 | 12.400002 | 40.366287 | QAM256 | 1 |
2 | 146750000 | 12.500000 | 40.366287 | QAM256 | 2 |
3 | 154750000 | 12.699997 | 40.366287 | QAM256 | 3 |
4 | 162750000 | 12.000000 | 40.366287 | QAM256 | 4 |
5 | 170750000 | 11.300003 | 40.366287 | QAM256 | 5 |
6 | 178750000 | 10.500000 | 40.366287 | QAM256 | 6 |
7 | 186750000 | 10.099998 | 38.983261 | QAM256 | 7 |
8 | 194750000 | 9.400002 | 38.983261 | QAM256 | 8 |
9 | 202750000 | 9.599998 | 38.605377 | QAM256 | 9 |
10 | 210750000 | 10.099998 | 40.366287 | QAM256 | 10 |
11 | 218750000 | 10.400002 | 40.366287 | QAM256 | 11 |
12 | 226750000 | 10.400002 | 40.366287 | QAM256 | 12 |
13 | 234750000 | 10.400002 | 40.366287 | QAM256 | 13 |
14 | 242750000 | 10.500000 | 40.946209 | QAM256 | 14 |
15 | 250750000 | 10.599998 | 40.946209 | QAM256 | 15 |
16 | 258750000 | 11.699997 | 40.366287 | QAM256 | 16 |
17 | 266750000 | 12.400002 | 40.366287 | QAM256 | 17 |
18 | 274750000 | 12.199997 | 40.946209 | QAM256 | 18 |
19 | 282750000 | 11.900002 | 40.366287 | QAM256 | 19 |
20 | 290750000 | 12.199997 | 40.366287 | QAM256 | 20 |
21 | 298750000 | 12.300003 | 40.366287 | QAM256 | 21 |
22 | 306750000 | 12.800003 | 40.366287 | QAM256 | 22 |
23 | 314750000 | 12.500000 | 40.366287 | QAM256 | 23 |
24 | 322750000 | 11.199997 | 40.366287 | QAM256 | 24 |
26 | 338750000 | 10.500000 | 40.366287 | QAM256 | 26 |
27 | 346750000 | 10.900002 | 40.366287 | QAM256 | 27 |
28 | 354750000 | 11.199997 | 40.366287 | QAM256 | 28 |
29 | 362750000 | 11.099998 | 40.366287 | QAM256 | 29 |
30 | 370750000 | 11.000000 | 40.366287 | QAM256 | 30 |
31 | 378750000 | 10.900002 | 40.366287 | QAM256 | 31 |
25 | Locked | 40.946209 | 0 | 0 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 38.983261 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.605377 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.946209 | 0 | 0 |
15 | Locked | 40.946209 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.946209 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
33 | 94 | 4K | 1840 | QAM4096 | 424 |
33 | Locked | 43 | 14.6 | 168312437 | 0 |
19-09-2022 17:57 - edited 19-09-2022 17:57
1 | 49600000 | 33.520599 | 5120 KSym/sec | 32QAM | 1 |
2 | 23600000 | 32.770599 | 5120 KSym/sec | 64QAM | 5 |
3 | 36600000 | 32.770599 | 5120 KSym/sec | 64QAM | 3 |
4 | 43100000 | 33.020599 | 5120 KSym/sec | 64QAM | 2 |
5 | 30100000 | 32.770599 | 5120 KSym/sec | 64QAM | 4 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
11 | 10.4 | 29.5 | 2K | QAM8 |
11 | OFDMA | 208 | 53.4 | 0 | 0 |
20-09-2022 12:58 - edited 20-09-2022 12:58
1 | 43100000 | 33.270599 | 5120 KSym/sec | 64QAM | 2 |
2 | 49600000 | 33.770599 | 5120 KSym/sec | 64QAM | 1 |
3 | 36600000 | 33.020599 | 5120 KSym/sec | 64QAM | 3 |
4 | 23600000 | 33.020599 | 5120 KSym/sec | 32QAM | 5 |
5 | 30100000 | 32.770599 | 5120 KSym/sec | 32QAM | 4 |
1 | US_TYPE_STDMA | 0 | 1 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 1 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 1 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 1 | 0 | 0 |
5 | US_TYPE_STDMA | 0 | 1 | 0 | 0 |
11 | 10.4 | 29.8 | 2K | QAM8 |
on 22-09-2022 13:42
Hi thinksingle,
Thank you for reaching out to us in our community and welcome, sorry to see you are experiencing high latency and pack loss, I was able to locate you on our System with the details we have for you and cannot see any long term issues, I can see you have a 3rd party Router so can only check so much, please can you do a Pin reset to put the Router back in Router mode enabling us to run further checks.
have you tried a pin reset to rule out any software issues, push a pin/ paper clip in the reset hole, it is important that it is held in for a timed 1 Minute, please allow 15 minutes to settle afterwards, please note if you have changed the Router password or any settings these will revert back to factory settings and will need changing back if needed.
Paul.
on 22-09-2022 15:17
@Paul_DN wrote:Hi thinksingle,
Paul.
Did you look at the power levels and BQM?
Downstream power is out of spec on most channels and QAM is off on a couple of the upstream channels.
on 22-09-2022 16:43
on 22-09-2022 20:01
Given the area has 5 x SC-QAMs and has an OFDMA upstream channel as well I'd hope not.
on 22-09-2022 23:17
Hello Paul,
I have followed your instructions however the issue still persists with one of my upload channels dropping to 16QAM and experiencing high latency and packet loss as can be seen in my BQM:
1 | 43100000 | 33.020599 | 5120 KSym/sec | 64QAM | 2 |
2 | 49600000 | 33.520599 | 5120 KSym/sec | 64QAM | 1 |
3 | 23600000 | 32.770599 | 5120 KSym/sec | 16QAM | 5 |
4 | 36600000 | 32.770599 | 5120 KSym/sec | 64QAM | 3 |
on 25-09-2022 13:48
Hi thinksingle, thank you for getting back in touch!
Sincerest apologies that you are still experiencing issues on your connection.
Having had a look at our systems I can see some issues at the exchange which will require a technicians appointment to resolve.
I will send you a PM to get this booked in for you! You can find the PM in the top right corner of the page in your Inbox.
All the best.
on 25-09-2022 15:45
Given the DS levels, the drop cable is probably on the wrong tap in the cabinet. Moving the coax to 10dB lower tap connection would drop the DS by 10dB, and the CMTS would then tell the modem to adjust US to around 42dBmv. US SNR at the CMTS (which you cannot see on the modem) will almost certainly improve. Easy fix.
