  • 607
  • 10
  • 49
DarkBahamut
Fibre optic
High power levels
We had some upgrade work in our area today and it would appear that whatever this entailed has caused our downstream power levels to climb to some rather high levels. I guess we've had some cab work and been put back onto the wrong tap considering we're right next to the cab here.
Fortunately the connection is actually working OK for the moment, but I'm a bit worried it isn't going to hold up long term since the levels seem rather over spec from what I recall. Any chance someone coming out to the cab and sorting us back to a decent level? 🙂
132300000017.940256 qam24
213900000018.540256 qam1
314700000018.540256 qam2
415500000018.543256 qam3
516300000018.440256 qam4
617100000018.140256 qam5
717900000018.140256 qam6
818700000018.140256 qam7
919500000018.340256 qam8
1020300000018.443256 qam9
1121100000018.440256 qam10
1221900000018.143256 qam11
132270000001840256 qam12
142350000001840256 qam13
1524300000017.840256 qam14
162510000001843256 qam15
172590000001840256 qam16
182670000001840256 qam17
192750000001840256 qam18
202830000001840256 qam19
2129100000017.840256 qam20
2229900000017.940256 qam21
2330700000017.940256 qam22
2431500000017.840256 qam23
1257998733.275512064 qam52
2326000003.35512064 qam51
3394000003.45512064 qam50
4462000003.475512064 qam49
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Re: High power levels
Those downstream levels are quite impressive.
You have called this spot on.
  • 756
  • 34
  • 66
Hi Darkbahamut ,
Thanks for getting in touch.
Sorry to see these downstream levels.
I would love to check thing's from our end and arrange an engineer if needed, in order to do this I have sent you a private message so we can get your details and access your account, please reply when you can 🙂
All the best,
Hetty_R
  • 12.98K
  • 993
  • 2.98K
hey @Hetty_R - puzzled why you need to check anything - the first post speaks for itself - first thing the OP needs is a tech
i know things have changed but why do you need to access his account - can you just not look at the levels assuming OP is posting from his connection
____________________
Tony
