JohnSmith123
  • 20
High ping spikes, intermittent connection, very slow speeds
I saw this thread back in November, where someone was complaining about having high ping spikes: https://community.virginmedia.com/t5/Speed/High-Ping-Spikes/td-p/4870272
I experienced the same issue around the same time. It never really went away, but I think it got a little bit better after a while.
But over the past few weeks or month or so, the issue has returned. Basically, the internet connection will be working fine, and then suddenly it'll become dead slow for some number of seconds or minutes. A speed test will show a ridiculously low (bytes or kilobytes per second) speed, and a ridiculously high ping (10+ full seconds).
Today it has been especially bad, being extraordinarily slow to the point of being unusable. It's at the point where I'm having to go off and make lunch while waiting for a individual, simple text web page to load.
Here's my Think Broadband data from the past week:
What's going on here?
  • 6.82K
  • 593
  • 1.79K
Re: High ping spikes, intermittent connection, very slow speeds
BQM showing peak time latency issues for Virgin Media users | thinkbroadband
The "yellow" humps are affecting all VM users, but your BQM is being affected by something else as well.
You need to post your power levels and network logs from the Hub, to see if we can spot something amiss.
Kain_W
  • 3.77K
  • 105
  • 268
Hi JohnSmith123,
Thanks for your post and welcome back to the community!
So sorry for any issues faced regarding the broadband, from checking our system everything seems to be in spec currently.
Are you able to post any recent logs?
Kain
