Hi @RyZe_Misty
Thanks for posting a BQM, this all looks fairly healthy - can you confirm for us if you rebooted your Hub at 12.30?
If the issues persist, can you please perform a Pinhole reset on your Hub by following these exact instructions:
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
This will be a factory reset on your Hub, so make sure to write down any passwords beforehand.
Let me know how you get on afterwards 🙂
Serena
