High Post RS errors, no ranging response
smllmn
After persistent issues over the last 5 days with connecting to telegram and gmail (the former will hang on "connecting" for 15-30 seconds at a time before establishing a connection, the latter simply will not load the modern client), I've been digging into the hub data and I'm a little disconcerted by what I see.
Full logs are below, but I'm seeing quite a lot of post RS errors and a few upstream sync issues. I've also observed spikes of seriously high upload latency - spikes as high as multiple seconds with median latency in the low hundreds of milliseconds.
120300000010.940256 qam9
213900000011.940256 qam1
314700000011.840256 qam2
415500000011.540256 qam3
516300000011.540256 qam4
617100000011.440256 qam5
717900000011.440256 qam6
818700000011.140256 qam7
91950000001140256 qam8
1021100000010.840256 qam10
1121900000010.540256 qam11
1222700000010.440256 qam12
1323500000010.340256 qam13
142430000009.940256 qam14
152510000009.840256 qam15
162590000009.540256 qam16
172670000009.540256 qam17
182750000009.540256 qam18
192830000009.940256 qam19
202910000009.940256 qam20
2129900000010.140256 qam21
2230700000010.140256 qam22
233150000001040256 qam23
243230000001040256 qam24
1Locked40.9280105
2Locked40.3316179
3Locked40.3326160
4Locked40.3283190
5Locked40.3317229
6Locked40.3304116
7Locked40.3332146
8Locked40.3289207
9Locked40.3284136
10Locked40.3318115
11Locked40.9254174
12Locked40.9254124
13Locked40.329984
14Locked40.325689
15Locked40.328670
16Locked40.326578
17Locked40.326868
18Locked40.9270107
19Locked40.328889
20Locked40.325354
21Locked40.327279
22Locked40.324948
23Locked40.327248
24Locked40.327673
14960000034.3512064 qam1
22359989733.3512064 qam5
34310000034512064 qam2
43010000033.8512064 qam4
53660003934512064 qam3
1ATDMA0010
3ATDMA0010
4ATDMA0000
5ATDMA0000
05/09/2022 04:00:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/09/2022 17:20:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/09/2022 13:04:59Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/09/2022 13:04:55criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/09/2022 13:04:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/09/2022 13:04:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2022 00:21:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2022 14:02:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2022 09:08:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2022 08:56:33criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2022 08:54:9Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2022 08:54:6criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2022 08:54:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2022 08:54:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
(notices omitted for brevity)
Any ideas on what the issue might be, or if this is an upstream issue that needs referring to VM, would be greatly appreciated.
1 REPLY 1
Akua_A
Hi @smllmn,
Welcome to our community forums and thank you for your first posts.
Sorry to hear you have been having issues with your service. We can understand the frustration caused and we want to best help. I have had a look into your service and I can see there may bee an issue with your power levels. For this reason, I am sending you a private message. Please look out for the purple envelope and provide a response when you can.
Akua_A
