angelastinson
  • 43
Message 1 of 22
High Ping and packet loss
Hi I'm getting very high ping spikes and constant packet loss, here is my ping test to Google's ip on my router and heres my stats . Please any help? Acquired Downstream Channel (Hz)
483000000
Locked
Ranged Upstream Channel (Hz)
46200019
Locked
Provisioning State
Online
ID
1483000000040256 qam30
21870000001.540256 qam7
31950000001.238256 qam8
42030000001.240256 qam9
52110000000.938256 qam10
62190000000.440256 qam11
72270000000.538256 qam12
82350000000.740256 qam13
92430000000.438256 qam14
ID
1462000194.525512064 qam1
2258000004.525512064 qam4
3325999984.525512064 qam3
4394000004.525512064 qam2
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
UBsgvca69834ncxv9873254k;fg87ds
SFID348
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID347
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 22
Re: High Ping and packet loss
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
angelastinson
  • 43
Message 3 of 22
Alex_RM
  • 4.52K
  • 260
  • 344
Message 4 of 22
Hi angelastinson,
Thanks for posting and welcome to our community 🙂
Sorry to hear you're having some issue with your connections.
How're things since your post on the 17th? Do you have an up to date BQM?
Alex_Rm
angelastinson
  • 43
Message 5 of 22
Still spiking to 200 ping plus and disconnects, especially at peak time, this is getting so annoying now https://www.thinkbroadband.com/broadband/monitoring/quality/view/50d6958e390cfba790be8b268d9d0d82402...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 22
Link comes up as 'Page Not Found'.
Andrew-G
  • 7.03K
  • 1.22K
  • 3.07K
Message 7 of 22
Your last BQM link is to your logged-in profile on Thinkbroadband, so it doesn't work for anybody other than you.  You'll need to put up a link to a shared graph (I suggest a "live" graph at that).  Don't post an image or screenshot from your logged in account, it'll not be approved because it shows your IP address.
You may also want to re-post the hub's status data - when you did so before, your technique was right (selecting text, pasting as formatted text) but you hadn't included the full set of data, as each tab extends downwards.  For example there's 24 downstream channels, and error data per channel, but you only selected the power and SNR data for the first nine.  Also, the Network log is sometimes helpful in showing up a problem.  It is important that you post these as text, so that the forum software can obscure personal data like the IP addresses and MAC addresses - when you do that it'll throw up an "invalid HTML message", just click on "post" again.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 22
angelastinson
  • 43
Message 9 of 22
My BQM
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b12c09a8fca1b6c990bc8585583406a2ee166248-26-09-2020
Its usually even worse than this tbh. And seems a lot worse when I'm in router mode and not modem mode.
angelastinson
  • 43
Message 10 of 22
My BQM today
