  • 8
Message 1 of 11
Hi my broadband speed is terrible.
These are my results:
Result ID
 PING ms
24
 DOWNLOAD Mbps
43.11
 UPLOAD Mbps
20.09
Connections
Multi
Manchester
Virgin Media
[REMOVED]
RATE YOUR PROVIDER
Virgin Media
 [MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 8
Message 2 of 11
Re: Hi my broadband speed is terrible.
By the way I am on M200?
  • 6.37K
  • 470
  • 835
Hero
Message 3 of 11
Firstly set up a BQM at thinkbroadband.com - this will give you an insight into what is happening with the signal coming into the property, it will take a few hours to get any kind of trend showing.
Then
Type 192.168.0.1 into your browser URL bar and press enter.  When the page appears DO NOT LOG IN but click ‘Check Router Status’. Copy and paste the contents of each tab onto here, a Guru will be along in the not too distant future to decipher the info.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 8
Message 4 of 11
Righto will do, thanks
  • 8
Message 5 of 11
Information
Cable Modem EuroDOCSIS 3.0 Compliant
Serial Number 483152WX0B718
Boot Code Version PSPU-Boot 1.0.20.1391
Software Version V2.01.15
Hardware Version 1.03
CA Key Installed
Acquired Downstream Channel (Hz) 154750000 Locked
Ranged Upstream Channel (Hz) 46200000 Success
Provisioning State OK Operational
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 154750000 138750000 146750000 162750000 170750000 178750000 186750000 194750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 3 1 2 4 5 6 7 8
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV) 10.36 10.21 10.24 10.33 10.08 10.06 10.07 9.85
RxMER (dB) 37.09 36.84 36.84 37.09 37.64 37.09 37.64 37.36
Pre RS Errors 3384 2740 622 520 331 313 336 913
Post RS Errors 281 281 299 278 305 288 306 890
Upstream  US-1 US-2 US-3 US-4
Channel Type 2.0 2.0 2.0 2.0
Channel ID 1 4 3 2
Frequency (Hz) 46200000 25800000 32600000 39400000
Ranging Status Success Success Success Success
Modulation 64QAM 64QAM 64QAM 64QAM
Symbol Rate (Sym/sec) 5120000 5120000 5120000 5120000
Mini-Slot Size 4 4 4 4
Power Level (dBmV) 41.00 41.00 41.00 41.00
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
Upstream Burst  Req(1) Init Maint(3) Per Maint(4) Adv Short(9) Adv Long(10) Adv UGS(11)
Modulation Type 16QAM QPSK 16QAM 64QAM 64QAM 16QAM
Differential Encoding OFF OFF OFF OFF OFF OFF
Preamble Length 36 384 384 64 64 64
Preamble Value Offset 396 6 6 396 396 396
FEC Error Correction (T) 0 5 5 7 14 5
FEC Codeword Information Bytes (K) 16 34 34 88 220 86
Maximum Burst Size 0 0 0 3 0 28
Guard Time Size 22 48 48 22 22 22
Last Codeword Length Fixed Fixed Fixed Shortened Shortened Shortened
Scrambler On/Off ON ON ON ON ON ON
General Configuration
Network Access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode EuroDOCSIS 3.0
Config File
SFID 750
Max Traffic Rate 230000061 bps
Max Traffic Burst 42600 bytes
Min Traffic Rate 0 bps
Primary Upstream Service Flow
SFID 749
Max Traffic Rate 22000061 bps
Max Concatenated Burst 42600 bytes
Scheduling Type Best Effort
First Time Last Time Priority Error Number Description
03/02/2020 15:28:21 GMT 03/02/2020 15:28:21 GMT Warning (5) 66050310 Auth Success - Web login successful.
03/02/2020 15:25:06 GMT 03/02/2020 15:25:06 GMT Warning (5) 66050310 Auth Success - Web login successful.
31/01/2020 03:16:33 GMT 31/01/2020 03:16:33 GMT Error (4) 68010302 DHCP WAN IP -  [REMOVED]
31/01/2020 03:15:34 GMT 31/01/2020 03:15:34 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
28/01/2020 11:19:23 GMT 28/01/2020 11:19:23 GMT Notice (6) 68010600 DHCP Renew - lease parameters tftp file-******** modified
28/01/2020 11:19:23 GMT 28/01/2020 11:19:23 GMT Error (4) 68010400 DHCP REBIND WARNING - Field invalid in response
28/01/2020 11:18:41 GMT 28/01/2020 11:18:41 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
28/01/2020 11:18:00 GMT 28/01/2020 11:18:00 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
28/01/2020 11:16:40 GMT 28/01/2020 11:16:40 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
28/01/2020 11:14:00 GMT 28/01/2020 11:14:00 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
28/01/2020 11:08:40 GMT 28/01/2020 11:08:40 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
28/01/2020 10:58:01 GMT 28/01/2020 10:58:01 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
28/01/2020 10:36:43 GMT 28/01/2020 10:36:43 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
28/01/2020 09:54:06 GMT 28/01/2020 09:54:06 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
28/01/2020 08:28:53 GMT 28/01/2020 08:28:53 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
28/01/2020 05:38:26 GMT 28/01/2020 05:38:26 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
27/01/2020 23:57:34 GMT 27/01/2020 23:57:34 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
27/01/2020 12:35:49 GMT 27/01/2020 12:35:49 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
24/01/2020 01:16:12 GMT 24/01/2020 01:16:12 GMT Notice (6) 68010600 DHCP Renew - lease parameters tftp file-******** modified
There we go that's everything on my Router status
  • 8
Message 6 of 11
This issue is in no way solved, what do I have to do next???
  • 1.29K
  • 183
  • 613
Message 7 of 11
Your downstream power levels are somewhat on the high side, but there are no log entries to indicate that this is causing any issues.
The important question to ask is, in your original post regarding speed, how were you measuring it? Was it a device connected directly via an Ethernet cable - which is the only reliable method, or over a device connected via wifi?
  • 8
Message 8 of 11
Thanks, it was measured on my laptop via wifi. by the way I have absolutely no idea what this means:-
Your downstream power levels are somewhat on the high side??????
  • 15.46K
  • 1.62K
  • 2.64K
Message 9 of 11
Post up your BQM (or a link to it).
Basically your down power levels are just outside of the recommended range (-6 to +10 dBmV) and probably need bringing down into range by a tech visit.
  • 8
Message 10 of 11
Thanks for your reply, would that increase my broadband speed?
