Aod1984
  • 49
Message 1 of 5
Help with stable connection speeds
 I have been asked by your team on tweeter to repost here i am having issues with my broadband after speeding 1.5 hours on the phone to your agent they could not offer a resolution other than go complain to ofcom I don't want my service cancelled just want it working my speeds on wireless go as low as 10mb when I do a pin hole reset or a reboot through app they go back up for a few hours or sometimes a few days my wired connection is getting about 30-40 mb have have checked all cables ect I done test on app which says there is a issue when your agent done one tbey said there was none clearly there is some issue but I have done 12 or 13 tests since August 15th when this started and nothing has changed keep getting same message that yours are working on it but I am paying for a service i am not getting i am on the 200 m package
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Help with stable connection speeds
It is doubtful that Wi-Fi from a VM Hub (or any other Hub) will ever get stable speeds.
How is the stability using an ethernet cable connected device ?
Aod1984
  • 49
Message 3 of 5
30-40mb through eithernet cable my package is for 200mb
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 5
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Emily_G
  • 4.82K
  • 209
  • 286
Message 5 of 5
Thanks for the post Aod1984 and welcome to our community.
We can see some downstream power level errors so I've booked you an engineer appointment using the forum information.
Please check these details and reschedule if needed on your online account.
Thanks, Emily.
