danbottomburp
  • 60
  • 6
Message 1 of 36
Help with connection please
I have been getting frequent drop outs on this connection, they last for a few seconds and then its fine again, was way worse on the first day of activation, have some what improved but still getting them
If you need more info then please let me know
Here are the logs
14620002143.3512064 qam3
23940000043.3512064 qam4
33260014143512064 qam5
42580000043.3512016 qam6
1ATDMA0040
2ATDMA00180
3ATDMA00220
4ATDMA00500
13310000006.538256 qam25
22030000007.538256 qam9
32110000007.438256 qam10
42190000007.538256 qam11
52270000007.438256 qam12
6235000000738256 qam13
72430000006.438256 qam14
82510000006.438256 qam15
92590000006.638256 qam16
102670000006.938256 qam17
112750000006.840256 qam18
122830000006.838256 qam19
132910000006.538256 qam20
142990000006.938256 qam21
153070000006.838256 qam22
163150000006.938256 qam23
173230000006.538256 qam24
183390000006.638256 qam26
19347000000738256 qam27
203550000006.940256 qam28
213630000006.538256 qam29
223710000006.538256 qam30
233790000006.838256 qam31
243870000006.538256 qam32
1Locked38.923286250953
2Locked38.95903732210867
3Locked38.94886404158376
4Locked38.93989087129327
5Locked38.93573655114421
6Locked38.93054676106218
7Locked38.92776241102575
8Locked38.9241345894991
9Locked38.9179715182634
10Locked38.9134753575212
11Locked40.3108136971400
12Locked38.987963567615
13Locked38.974788964711
14Locked38.957419062143
15Locked38.944759058314
16Locked38.936257056093
17Locked38.930229652866
18Locked38.920115648319
19Locked38.916954646854
20Locked40.915546543930
21Locked38.915060342902
22Locked38.914759741399
23Locked38.613715039645
24Locked38.911956836468
  • 6.82K
  • 593
  • 1.79K
Message 2 of 36
Re: Help with connection please
Far too many T3 errors and PostRS errors, suggesting noise ingress on the line.    Reboot the Hub and check the PostRS errors and if they rise quickly, there is a problem.  VM will need to send a technician to sort this out.
I would suggest you also setup a BQM here www.thinkbroadband.com/ping   This will record the status of the incoming circuit.
danbottomburp
  • 60
  • 6
Message 3 of 36
I have just set up the BQM
This is the live link -
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7e694216ffa7dcd90bc617e903d9c8b6ab...
I will leave it for a few hours
danbottomburp
  • 60
  • 6
Message 4 of 36
Rebooted Hub and left that monitor running for quite some time now, can anyone tell me if i need to be getting an engineer please?
22030000007.540256 qam9
32110000007.540256 qam10
42190000007.540256 qam11
82510000006.538256 qam15
92590000006.838256 qam16
10267000000738256 qam17
112750000006.940256 qam18
122830000006.940256 qam19
132910000006.638256 qam20
153070000006.940256 qam22
183390000006.838256 qam26
223710000006.540256 qam30
233790000006.638256 qam31
1Locked38.94785341
2Locked40.311000712115
3Locked40.38050301759
4Locked40.35901921573
5Locked38.94971401445
6Locked38.93866631346
7Locked38.93246051295
8Locked38.92427771185
9Locked38.91475551000
10Locked38.993062847
11Locked40.363473759
12Locked40.344554673
13Locked38.932953609
14Locked38.920875552
15Locked40.313265496
16Locked38.99796444
17Locked38.97332386
18Locked38.93626319
19Locked38.92642296
20Locked40.32425260
21Locked38.92335233
22Locked40.32236222
23Locked38.62093201
24Locked38.91769177
14620009344.8512064 qam3
23939995244.8512064 qam4
33260009845512064 qam5
42580000044512032 qam6
3ATDMA0000
4ATDMA0000
danbottomburp
  • 60
  • 6
Message 5 of 36
Ok so i have noticed fewer dropouts but it is still happening just nowhere near as much, here are my router stats after a reboot the other day when asked to
13310000006.940256 qam25
22030000008.340256 qam9
32110000008.140256 qam10
4219000000840256 qam11
5227000000838256 qam12
62350000007.538256 qam13
72430000006.938256 qam14
8251000000738256 qam15
92590000007.438256 qam16
102670000007.540256 qam17
112750000007.440256 qam18
122830000007.340256 qam19
13291000000738256 qam20
142990000007.338256 qam21
153070000007.340256 qam22
163150000007.338256 qam23
173230000006.938256 qam24
18339000000738256 qam26
193470000007.440256 qam27
203550000007.140256 qam28
213630000006.840256 qam29
223710000006.840256 qam30
23379000000738256 qam31
243870000006.838256 qam32
1Locked40.3288881290
2Locked40.313980054485
3Locked40.310399553797
4Locked40.37811133500
5Locked38.96694583319
6Locked38.95321843181
7Locked38.94538083074
8Locked38.93512302907
9Locked38.92326422658
10Locked40.31627572503
11Locked40.31227512266
12Locked40.3964712109
13Locked38.9791412006
14Locked38.9601431898
15Locked40.3472681733
16Locked38.9404091585
17Locked38.6345911403
18Locked38.9255971189
19Locked40.3220191029
20Locked40.319696926
21Locked40.318390817
22Locked40.316966774
23Locked38.615546680
24Locked38.913481574
14620000045.5512064 qam3
23940000046.3512064 qam4
33259998647.3512032 qam5
42580000048.8512016 qam6
3ATDMA0010
4ATDMA0020
29/01/2022 08:18:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2022 03:07:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2022 10:56:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2022 08:54:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Can someone please let me know if i need an engineer?
danbottomburp
  • 60
  • 6
Message 6 of 36
So i have had the BQM running for a few days now, the link is posted above if you would like to see that, still getting occasional dropouts and the Errors have returned in a big way too
1331000000740256 qam25
22030000008.440256 qam9
32110000008.340256 qam10
42190000008.340256 qam11
52270000008.138256 qam12
62350000007.638256 qam13
7243000000738256 qam14
112750000007.540256 qam18
122830000007.540256 qam19
132910000007.138256 qam20
142990000007.438256 qam21
153070000007.440256 qam22
163150000007.438256 qam23
17323000000738256 qam24
183390000007.338256 qam26
193470000007.540256 qam27
203550000007.440256 qam28
21363000000740256 qam29
223710000006.940256 qam30
233790000007.338256 qam31
24387000000738256 qam32
1Locked40.3289101290
2Locked40.313980384485
3Locked40.310400233797
4Locked40.37812093526
5Locked38.96706183323
6Locked38.95359423209
7Locked38.94570083103
8Locked38.93516792924
9Locked38.92327532658
10Locked40.31628162503
11Locked40.31227902266
12Locked40.3965212109
13Locked38.9792182006
14Locked38.9602541898
15Locked40.3473031733
16Locked38.9404411585
17Locked38.9346171403
18Locked38.6256211189
19Locked40.3220571029
20Locked40.319744926
21Locked40.318430817
22Locked40.917004774
23Locked38.915571680
24Locked38.913510574
Please advice on if i need an engineer
-tony-
  • 19.22K
  • 1.46K
  • 3.76K
Message 7 of 36
pre and post rs errors are a mess - you can check all coax connections are tight but - yes - i would guess you need a tech to sort that out - wait for VM to get to the thread they will book someone
____________________
Tony.
Sacked VIP
Tom_W1
  • 3.66K
  • 198
  • 342
Message 8 of 36
Hi @danbottomburp, thanks for your post although I'm really sorry you're having connection problems.
Apologies for the delay in getting back to you, but it appears you've already got things moving on this by giving us a call.
Please let me know if you need any further help once the technician has visited you!
Many thanks
Tom_W
danbottomburp
  • 60
  • 6
Message 9 of 36
Well i thought everything was sorted but checking my BQM over last few days it appears not all is good at all
Here is the link -
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ac34fd4c9281748e838a5f353a78c05971...
@Tom_W1
Kain_W
  • 3.76K
  • 105
  • 268
Message 10 of 36
Hi danbottomburp,
Thanks for your post and welcome back to the community!
Sorry to see you're facing further issues with your service.
Currently our Field team have raised an area fault that has as estimated fix time of around 6PM today.
You can use our website link for reference.
Our team will work as efficient as possible to get that sorted for you.
Let us know how your service is once the ticket has been resolved.
Cheers,
Kain
