  • 45
loopylinda
Message 1 of 5
Help with backup
Hope someone can help, but, the time that Windows is taking to perform a simple Maintenance backup, scheduled to back-up new or changed files since the last back-up (every week) these days is terrible! I started the last one four hours ago and I've just put the nineth (9th) CD-R in but it's only up to 43% complete!!! Am I doing something wrong?
Using Windows 10, x64
3.00 GB RAM
Have Fibre 20 with 30GB data but only use approx 8GB per month
234GB data free of a total 297GB
Haven't been able to carry out a back-up since I upgraded to Windows 10 last year!!! It used to take no time at all and use just 1 disk, help!
  • 598
  • 22
  • 79
happywithmy350
Rising star
Message 2 of 5
Re: Help with backup
Yes get out the 90s and stop backing up windows.
You are probably the only person who does this - and anyway this is nothing to do with the internet connection
  • 3.2K
  • 217
  • 510
Roger_Gooner
Wise owl
Message 3 of 5
A CD-R holds only 700 MB! Why not use something else such as a flash drive, optical drive or portable drive. I back up my data to an internal drive, a NAS and to cloud.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 2.47K
  • 38
  • 211
jhuk
Super solver
Message 4 of 5
What does this have to do with Broadband Speed?
  • 86
  • 6
  • 14
goslow
Up to speed
Message 5 of 5
3GB memory spec's suggest this is not a new PC/laptop. If you did an in-situ upgrade to Win 10 then there will be a lot of bloated remnants on your device from the previous operating system which will, no-doubt, have increased your backup times and storage capacity requirements.
Follow Roger_Gooner's suggestion and consider some kind of external device (hard drive etc.) to back up to.
This will work best/quickest if you are using USB 3.0 connections or above (which you may probably not have at the moment).
I use 'Macrium Reflect Free' for backups which is a brilliant program, very reliable and, of course, ..... free!
Suggest you find a friendly local PC shop (Trustmark, Which Trusted Trader recommended etc. etc.) and go ask them for some help/advice on the issue.
None of this has anything to do with broadband speed, so one of the forum team or super users may re-home it in a better location.
