pjskyboy
  • 14
Help requested for recent speed drops from 200 down to 45 to 2 Mbps
sought help here before and it has proven worthwhile so thought I'd try again.
Recently (and intermittently over the last 2-3 months) my 200Mbps link drops down to 45 Mbps.
SH 2ac
Modem mode
Google Wifi router
PC Windows 10, wired to router cat6 cable via a netgear switch
(measured by Google Wifi router - so "raw" speed) sometimes down to 2 Mbps (dslreports.com browser-based on PC wired to Google Wifi on CAT 6 cable). Other devices on Wifi report similar speed drops using dslreports.com
On the PC I notice the degradation most using Citrix for accessing work - gets very jittery
Checked all my connections are tight.
Reverted to router mode to set up a BQM.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/01f66d754023e3a3b654193836e1a767f8ed0b4a
In router mode I still get severe degradation - which suggests a Virgin issue? And quite variable performance within the 45 Mbps bandwidth currently available.
Stats from router network diagnostics:
Downstream ChannelsLock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked17266750000 Hz256 QAM-6.7 dBmV 31.4 dB5720241666
Locked18274750000 Hz256 QAM-6.5 dBmV 26.7 dB3365929714738610
Locked19282750000 Hz256 QAM-7.7 dBmV 31.5 dB2695904432
Locked20290750000 Hz256 QAM-7.8 dBmV 30.2 dB6153281450
Locked21298750000 Hz256 QAM-7.1 dBmV 34.1 dB49022412
Locked22306750000 Hz256 QAM-8.3 dBmV 32.9 dB1536062489
Locked23314750000 Hz256 QAM-6.6 dBmV 32.8 dB27070131312
Locked24322750000 Hz256 QAM-6.6 dBmV 34.0 dB2746895758
Upstream ChannelsLock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked439400000 HzATDMA47.0 dBmV64QAM6400000 Hz5120 Ksym/sec
Locked532600000 HzATDMA47.0 dBmV64QAM6400000 Hz5120 Ksym/sec
Locked346200000 HzATDMA47.0 dBmV64QAM6400000 Hz5120 Ksym/sec
Locked253700000 HzATDMA47.0 dBmV64QAM6400000 Hz5120 Ksym/sec
DJ_Shadow1966
  • 7.14K
  • 1.36K
  • 2.02K
Re: Help requested for recent speed drops from 200 down to 45 to 2 Mbps
Hello
You are going to need an engineer visit as some of your downstream power levels are below specs, most of them are below the threshoold of 34.
I have escalated to the VM forum team, one of the VM staff will be along in this thread to resolve it for you.
Regards Mike
pjskyboy
  • 14
Connected PC directly to SH 2ac in router mode.
Speed seems to be capped at 45 Mbps, and drops to 2 Mbps seemingly randomly - which may coincide with Citrix sessions "stalling"? Do Virgin cap speeds to load balance or whilst under maintenance?
This matches the experience when using the google router and SH in modem modem
So as far as I can see running in Router mode or modem mode makes little difference.
All of this started about 14th Oct I can see from Google logs the regular automated speed test was running at or around 200 Mbps. Previous similar speed "cap" was for a about a week in early September.
Oddly upload is relatively consistently stable at 18-20 Mbps thruout
pjskyboy
  • 14
Thank you Mike. I'll look out for them.
pjskyboy
  • 14
I think I have fixed it - there was a loose in the garage where "someone" had knocked the cable loose from its housing. Pushed it back in and now the speed is back to normal.
Downstream:
RxMER (dB)36.1736.6135.9735.9736.1736.6136.3936.84
Earlier checks had just been on the router itself - doh!
DJ_Shadow1966
  • 7.14K
  • 1.36K
  • 2.02K
Hello
Glad it is solved.
Your welcome, if you have any more queries by all means come on back to the forum we do have a great team of VM staff members, VIPs and normal customers with a great deal of knowledge. Stay safe and have a great weekend.
Regards Mike
