  • 121
  • 9
fiesata
Up to speed
Message 1 of 8
Help needed re UL config after upgrade
I upgraded to M200 yesterday and  am already getting over 200 m down but only 12mb up as I was with my 152m before
The receipt I was emailed states 20 mb upstream and it also states that Here
 Advertised Speed*Expected Speed Range**Minimum Guaranteed Download Speed Advertised Speed*Expected Speed Range**
M5054 Mbps53 - 55 Mbps27 Mbps3 Mbps3 Mbps
M100108 Mbps105 - 109 Mbps54 Mbps6 Mbps6 Mbps
M200213 Mbps200 - 218 Mbps107 Mbps20 Mbps21 Mbps
Called VM this morning spoke to 1st person he said the UL speed should have increased when upgrade was done and transferred me to techies
2nd call person said they don’t support UL speeds  I advised my router was still showing
Max Traffic Rate12700000
which meant I can never get  more than12 mb however he repeated constantly they don't support upload speeds and IMO was very rude and dismissive
3rd call person helpful but could not sort it for me said they would arrange callback within 1 hr - no one has called
4th call Ditto 2nd person
I'm hoping a Mod can help I've spent over 2 hours getting nowhere today
As per thread  HERE router stats should show Max Traffic Rate: 22000061
TIA
Paul
  • 10.2K
  • 1.06K
  • 1.62K
Message 2 of 8
Re: Help needed re UL config after upgrade
Noted that some people are now on 20mbps upload speeds on the 200 package.
I have that package but still on 12up. I have an SH2 though. I wonder if the increased up speed in only applied if you have a Hub3 ? Is yours a Hub3?
  • 121
  • 9
fiesata
Up to speed
Message 3 of 8
Yes I have Hub 3
  • 6.16K
  • 70
  • 468
Buffer6
Community elder
Message 4 of 8
Confirmed in Area 26
I had been out, left PC in sleep mode, when I came back Hub3 was flashing and beeping (maybe it was the PC beeping)
So I switched off Hub3 for 30 secs and rebooted
I'm on the M200 package.  Just now checking speedtest.net
Yep it has gone up to 20Mb/s on uploads 😃 It was 12Mb/s when last checked.
Thanks Virgin!! 👍
  • 6.16K
  • 70
  • 468
Buffer6
Community elder
Message 5 of 8
PS I discovered later that there had been a power cut during the time I was out and had nothing to do with the speed update 😃
  • 411
  • 5
Snoopzster
Superfast
Message 6 of 8
TIA
Paul
People are reporting that after a reboot this morning they now have it so give it another go.
  • 6.16K
  • 70
  • 468
Buffer6
Community elder
Message 7 of 8
@Snoopster
Maybe you already have, but did you sign in to https://my.virginmedia.com/home/index  and then check service and run the Broadband test
if it determines your Hub config is wrong it will then update to the new config.  Other than that it might not have rolled out in your area as yet
It might take a few days more
  • 121
  • 9
fiesata
Up to speed
Message 8 of 8
Rebooted Hub 3 today and as  if by magic 20M Thanks VM Smiley Happy
